Subject: Re: CSS Phoebus spinner step size
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Pietryla, Anthony F." <[email protected]>
Date: Fri, 21 Aug 2020 18:08:09 +0000
> How can I adjust the step size of a spinner widget in Phoebus without editing the display?
If you want to provide users with a way to adjust the "increment" property of a spinner in a display, you can add for example a text field adjacent to the spinner, connect it to a PV "loc://incr(1)", and then have a rule on the spinner that updates its "increment" property from that PV:
Add rule to spinner, trigger PV "loc://incr(1)", check "Value as _expression_", with just one _expression_ with boolean "true" and value "pv0".
Instead of a local PV for an increment that's per-display you could also use a global PV if all users of that spinner should use the same increment.
Instead of putting the increment PV on the display, you could also have a rule that computes the increment from for example the current value, i.e. the increment changes automatically based on the value.
-Kay
CSS Phoebus spinner step size Pietryla, Anthony F. via Tech-talk
Prev: CSS Phoebus spinner step size Pietryla, Anthony F. via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Ralph Lange via Tech-talk
Next: EPICS 7.0.4.1 released Michael Davidsaver via Tech-talk
