Subject: Re: running gateway on mac
From: "Smith, Martin via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Vivian O'Dell <[email protected]>
Date: Tue, 1 Sep 2020 14:22:37 +0000
Hi Vivian,
Do you have your access security files set up like the pvlist and access files?
If you don't set these up then you won't even get read access to PVs.
Hope this helps
Marty
From: Tech-talk <[email protected]> on behalf of Vivian O'Dell via Tech-talk <[email protected]>
Sent: Tuesday, September 1, 2020 9:07 AM
To: [email protected] <[email protected]>
Subject: running gateway on mac
I’m trying to run gateway on my mac. I have PVs defined in EPICs, and
if I use caget locally, it works fine, but when I try to use gateway I get the
following message:
mac-130048:darwin-x86 odell$ caget Tracker:LV1:Status
CAC: Unable to connect because "Connection refused"
Channel connect timed out: 'Tracker:LV1:Status' not found.
CAC TCP socket linger set error was Invalid argument
CAC TCP socket shutdown error was Socket is not connected
I am using the following command to start the gateway:
 ./gateway -sport 5069 -server
I also have the following environment variables set:
EPICS_BASE=/Users/odell//base-3.15.7
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=darwin-x86
EPICS_CA_ADDR_LIST=
EPICS_CA_NAME_SERVERS=localhost:5069
The result I get is:
I am using gateway 2.1.2. I get the same result with older versions
of gateway.
Any ideas of where to look for the problem?
thanks,
Vivian
Re: running gateway on mac Vivian O'Dell via Tech-talk
AreaDetector: PVs from driver created parameters not updating David Vine via Tech-talk
Re: AreaDetector: PVs from driver created parameters not updating Mark Rivers via Tech-talk
Prev: running gateway on mac Vivian O'Dell via Tech-talk
Next: Re: running gateway on mac Vivian O'Dell via Tech-talk
