Subject: running gateway on mac
From: Vivian O'Dell via Tech-talk <[email protected]>
Date: Tue, 1 Sep 2020 14:07:13 +0000
I’m trying to run gateway on my mac. I have PVs defined in EPICs, and
if I use caget locally, it works fine, but when I try to use gateway I get the
following message:
mac-130048:darwin-x86 odell$ caget Tracker:LV1:Status
CAC: Unable to connect because "Connection refused"
Channel connect timed out: 'Tracker:LV1:Status' not found.
CAC TCP socket linger set error was Invalid argument
CAC TCP socket shutdown error was Socket is not connected
I am using the following command to start the gateway:
 ./gateway -sport 5069 -server
I also have the following environment variables set:
EPICS_BASE=/Users/odell//base-3.15.7
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=darwin-x86
EPICS_CA_ADDR_LIST=
EPICS_CA_NAME_SERVERS=localhost:5069
The result I get is:
I am using gateway 2.1.2. I get the same result with older versions
of gateway.
Any ideas of where to look for the problem?
thanks,
Vivian
Re: running gateway on mac Smith, Martin via Tech-talk
AreaDetector: PVs from driver created parameters not updating David Vine via Tech-talk
Re: AreaDetector: PVs from driver created parameters not updating Mark Rivers via Tech-talk
Prev: Re: AreaDetector: PVs from driver created parameters not updating Mark Rivers via Tech-talk
Next: Re: running gateway on mac Smith, Martin via Tech-talk
