Subject: Re: dbpf equivalent for V4 records
From: Marty Kraimer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 2 Sep 2020 16:06:08 -0400
On 9/2/20 8:37 AM, Sandeep Kumar Malu - UKRI STFC via Tech-talk wrote:
Hi All,
In V3 db record, the values can be put in st.cmd using dbpf command. What is the equivalent command to put values to V4 PVA records in st.cmd?
Many Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
I assume you are referring to PVRecords as defined by pvDatabaseCPP.
There is no equivalent to dbpf.
There is a command pvdbl that is similar to dbl.
Note that the code that create a PVRecord can also give it initial values.
Marty Kraimer
RE: dbpf equivalent for V4 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Prev: Re: CAEN R1470ET HVPS - Asyn + Stream Device auto connect does Paduan Donadio, Marcio via Tech-talk
Next: Re: areaDetctor NDPluginProcess Background Saving Mark Rivers via Tech-talk
Prev: dbpf equivalent for V4 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: RE: dbpf equivalent for V4 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
