Hi Marty
Thank you for the suggestion. Yes, I can pass the value from st.cmd & in cpp file it can assign that value to PVRecord.
Many Thanks
Sandeep
On Behalf Of Marty Kraimer via Tech-talk
Sent: Wednesday, September 2, 2020 9:06 PM
To: [email protected]
Subject: Re: dbpf equivalent for V4 records
On 9/2/20 8:37 AM, Sandeep Kumar Malu - UKRI STFC via Tech-talk wrote:
Hi All,
In V3 db record, the values can be put in st.cmd using dbpf command. What is the equivalent command to put values to V4 PVA records in st.cmd?
Many Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify
the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own
virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments
that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
I assume you are referring to PVRecords as defined by pvDatabaseCPP.
There is no equivalent to dbpf.
There is a command pvdbl that is similar to dbl.
Note that the code that create a PVRecord can also give it initial values.
Marty Kraimer
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
- dbpf equivalent for V4 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
- Re: dbpf equivalent for V4 records Marty Kraimer via Tech-talk
Atomtex AT2327 Alarm Dosimeter Markus Kristensson via Tech-talk
Re: PTP hardware timestamps in EPICS facilities Michael Davidsaver via Tech-talk
<2020>
2025
2026
How to handle adjusting values as they change independent of the driver in an asynPortDriver? Wlodek, Jakub via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
