1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: NTNDArray display in CS-Studio
From: "Malu, Sandeep Kumar \(-, RAL, CLF\) via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 9 Sep 2020 13:39:38 +0000
Hi All,
I am using NDPluginPVA (https://cars9.uchicago.edu/software/epics/NDPluginPva.html) in Areadetector IOC with V4 PV Name “CAM:Pva1:Image”. Using ImageJ (EPICS_NTNDA_Viewer), I can see the camera streaming after putting Channel Name as “CAM:Pva1:Image”. I can also see the camera streaming on CS-Studio Phoebus using Image widget with PV name as “pva://CAM:Pva1:Image”.
My existing camera opis are based on CS-Studio SNS – 4.5.0 & currently uses Intensity Graph widget (NDStdArray plugin) to view the camera Image. After migrating to NDPluginPVA, I tried to use VImage & Intensity Graph widget with PV Name as “pva://CAM:Pva1:Image” , but no success. How I should proceed to use CS-Studio SNS -4.5.0 version to display the NTNDArray ?.
Many Thanks
Sandeep Malu
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Prev: Re: Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet victor levy via Tech-talk
Next: Attocube AMC100 Dougan, Niamh (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet Jeong Han Lee via Tech-talk
