1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet
From: Jeong Han Lee via Tech-talk <[email protected]>
To: victor levy <[email protected]>
Date: Wed, 9 Sep 2020 09:50:15 -0700
Hi Victor,
Please check iocBoot/iocEasyDriverTest/st.cmd file. That is the
startup script, which is used as an input file of your binary IOC file
that will be in bin/your_arch/ path.
And I am not good at answering your questions. I recommend you to
spend some time to do training yourself such as
https://epics.anl.gov/docs/APS2014.php
The following video may help you to understand how it works.
https://www.youtube.com/watch?v=S6kFh0voCOE
HTH,
Han
On Tue, Sep 8, 2020 at 11:00 PM victor levy <[email protected]> wrote:
> Thank you Jeong,
> I have the IP of the easy-driver and am trying to receive and send data(caget/caput) via ethernet cable (through port),
> How can this be done with epics?
> BR,
> Victor
> On Wed, Sep 9, 2020 at 4:25 AM Jeong Han Lee <[email protected]> wrote:
>> Hi Victor,
>>   1. Download CAENelsEasyDriver-0.1.35.zip from CAENels
>>   2. Extract it into a folder
>>   3. Configure your EPICS base by modifying RELEASE file in configure path
>>       ASYN = /home/mitja/Desktop/EPICS/Base_and_Extension/Asyn/asyn4-18/
>>       EPICS_BASE =
>> /home/mitja/Desktop/EPICS/Base_and_Extension/Base/base-3.14.12.5/
>>   4. Build
>> HTH,
>> Han
>> On Tue, Sep 8, 2020 at 1:20 PM victor levy via Tech-talk
>> > Hello,
>> > I am trying to connect a raspberry pi 3 to different CAENels EASY-DRIVER 0520 via ethernet,
>> > the goal is to receive data such as voltage and current, add to the database created by epics in the raspberry pi in real time and send to all computers via WIFI,
>> > I have installed epics on the RP( raspbian) and have the driver for the easy-driver with the following guide:
>> > file:///home/pi/epics/modules/instrument/5/Easy-Driver-EPICS-master/documentation/devCAENelsEasyDriver.html
>> > I do not understand how to install this driver, is there a guide or similar how-to I can follow?
>> > Thank you,
>> > Victor L.
Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet victor levy via Tech-talk
Re: Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet Jeong Han Lee via Tech-talk
Re: Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet victor levy via Tech-talk
Prev: Attocube AMC100 Dougan, Niamh (DLSLtd, RAL, LSCI) via Tech-talk
Next: Phoebus Logbook ui preferences Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Raspberry pi 3 -CAENels EASY-DRIVER 0520 - ethernet victor levy via Tech-talk
Next: NTNDArray display in CS-Studio Malu, Sandeep Kumar (-, RAL, CLF) via Tech-talk
