1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: mbbi record ignores mask?
To: 'Eric Norum' <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Tue, 15 Sep 2020 15:55:29 +0000
The mbbo documentation in the record Wiki (https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Multi-Bit_Binary_Output) says this:
MASK is used by device support routine to read the hardware register. Record support sets low order of MASK the number of bits specified in NOBT. Device support can shift this value.”
The 3.15.5 version of the mbbo record seems to do what the documentation says:
(base) corvette:src/std/rec>grep -i mask mbboRecord.c
    /* Initialize MASK if the user set NOBT instead */
    if (prec->mask == 0 && prec->nobt <= 32)
        prec->mask = ((epicsUInt64) 1u << prec->nobt) - 1;
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Tuesday, September 15, 2020 10:47 AM
To: 'Eric Norum' <[email protected]>; Johnson, Andrew N. <[email protected]>
Cc: [email protected] ([email protected]) <[email protected]>
Ø  The mbbi record in the couple of versions of base that Ive checked (3.15.5 and 3.15.7) don’t seem to use the MASK field.
I believe that is the responsibility of the device support.  asyn device support handles the mask.
From: Tech-talk <[email protected]> On Behalf Of Eric Norum via Tech-talk
Sent: Tuesday, September 15, 2020 10:45 AM
To: Johnson, Andrew N. <[email protected]>; [email protected]
Subject: mbbi record ignores mask?
This is one of those things that seems impossible to have been wrong for so long that it makes me wonder if I’m misinterpreting what I’m reading.
wenorum@xildev5 223> pwd
/eda/epics/R3.15.7/base/src/std/rec
wenorum@xildev5 224> grep -n mask mbbiRecord.c
140:    if (prec->mask == 0 && prec->nobt <= 32)
141:        prec->mask = ((epicsUInt64) 1u << prec->nobt) - 1;
wenorum@xildev5 225>
Eric Norum
RE: mbbi record ignores mask? Mark Rivers via Tech-talk
mbbi record ignores mask? Eric Norum via Tech-talk
Prev: RE: mbbi record ignores mask? Mark Rivers via Tech-talk
Next: Re: mbbi record ignores mask? Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: RE: mbbi record ignores mask? Mark Rivers via Tech-talk
