1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Problem with installing epics base on Jetson nano
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: 신동호 <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 15 Sep 2020 16:20:59 +0000
On Sep 15, 2020, at 3:38 AM, 신동호 via Tech-talk <[email protected]> wrote:
I'm trying to install epics base on NVIDIA Jetson nano (Ubuntu 18.04).
I typed make and got below messages.
epics@epics-desktop:~/EPICS/epics-base$ make
./src/tools/EpicsHostArch.pl: Architecture 'aarch64-linux-gnu-thread-multi' not recognized
configure/CONFIG:58: configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target 'configure/os/CONFIG..Common'.  Stop.
I looked inside EpicsHostArch.pl and found there was no rule for 'aarch64-linux-gnu-thread-multi'.
Can I add a rule for that? If possible, would you tell me how to do?
EPICS target names are not the same as Unix ones; the EPICS target name for your system should be linux-aarch64 but we only added the configuration files for that particular architecture to Base in the very latest release (EPICS 7.0.4.1) and only for cross-building that target. You may be able to use the linux-arm target instead though, try doing this:
$ export EPICS_HOST_ARCH=linux-arm
$ make
If that works you will need to set the EPICS_HOST_ARCH variable like that whenever you build EPICS code, so it might be worth putting that statement into your ~/.bashrc or ~/.profile file.
I would like to add full support for this architecture to EPICS though. if you want to help please send me the output from the command  perl -V  on that system.
- Andrew
Complexity comes for free, simplicity you have to work for.
Problem with installing epics base on Jetson nano 신동호 via Tech-talk
Prev: Re: mbbi record ignores mask? Johnson, Andrew N. via Tech-talk
Next: Re: SoftIOC Performance Evaluation Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Problem with installing epics base on Jetson nano 신동호 via Tech-talk
Next: Re: Problem with installing epics base on Jetson nano Johnson, Andrew N. via Tech-talk
