Subject: Multiple Archiver Appliances on same host, different NICs
From: Daniel Cuneo via Tech-talk <[email protected]>
To: Tech-talk <[email protected]>
Date: Sat, 19 Sep 2020 09:33:49 -0700
We are setting up a new host with enough resources to run 3 AA instances.
It makes sense to use more than a single NIC to handle a large network load.
The idea is to separate the AA instances and NICs, to cover different subnets with some overlap.
I'd rather not use a container like Singularity right off the bat, although that might end up beieng the  best practice after all.
In the appliances.xml file I know that I set the appliance id and inet which points to
directories in Tomcat.
Can I use a FQND like, appliance01.als.lbl.gov:17665 and another
entry, appliance02.als.lbl.gov:17665  and do forth ? Where the appliance ID is also the IP address.
Of course "appliance01" would have to match the Tomcat context directory as well, where  all the WAR files are deployed.
Or, do I just multihome the host and the Linux kernel handles it ? Then use different port ranges for each instance in the appliances.xml file.
Not really sure how to ask this question, thanks in advance for your patience.
Daniel Cuneo
ALS Accelerator Controls
BLD 46-172G
desk: 510-486-5439
cell:   415-871-1909
Re: Multiple Archiver Appliances on same host, different NICs Phillip A. Sorensen via Tech-talk
Prev: Device Support for Tektronix MSO58LP Cain, Michael Joseph via Tech-talk
Next: asyn R4-41 available Mark Rivers via Tech-talk
Next: Re: Multiple Archiver Appliances on same host, different NICs Phillip A. Sorensen via Tech-talk
