Subject: Re: Multiple Archiver Appliances on same host, different NICs
From: "Phillip A. Sorensen via Tech-talk" <[email protected]>
To: [email protected]
Date: Thu, 1 Oct 2020 10:26:02 -0400
I sounds like you are on the right track. We have setup with 3 AA that can run on the same machine (The setup is a 2 node pacemaker cluster).
What we did was
1. A tomcat setup for each AA
2. setup the appliance.xml with a single appliance0 entry that uses an IP address of the subnet/NIC it should listen on.
3. Set the EPICS_CA_AUTO_ADDR_LIST to NO and EPICS_CA_ADDR_LIST to the proper broadcast for the network for each tomcat.
Hope that helps.
Phil Sorensen
CHESS
On 9/19/20 12:33 PM, Daniel Cuneo via Tech-talk wrote:
We are setting up a new host with enough resources to run 3 AA instances.
It makes sense to use more than a single NIC to handle a large network load.
The idea is to separate the AA instances and NICs, to cover different subnets with some overlap. I'd rather not use a container like Singularity right off the bat, although that might end up beieng the  best practice after all.
In the appliances.xml file I know that I set the appliance id and inet which points to
directories in Tomcat.
Can I use a FQND like, appliance01.als.lbl.gov:17665 <http://appliance01.als.lbl.gov:17665/> and another entry, appliance02.als.lbl.gov:17665 <http://appliance02.als.lbl.gov:17665/>  and do forth ? Where the appliance ID is also the IP address. Of course "appliance01" would have to match the Tomcat context directory as well, where  all the WAR files are deployed.
Or, do I just multihome the host and the Linux kernel handles it ? Then use different port ranges for each instance in the appliances.xml file.
Not really sure how to ask this question, thanks in advance for your patience.
Daniel Cuneo
ALS Accelerator Controls
BLD 46-172G
desk: 510-486-5439
cell:   415-871-1909
Multiple Archiver Appliances on same host, different NICs Daniel Cuneo via Tech-talk
Prev: Re: Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
Next: ADPilatus John Dobbins via Tech-talk
Prev: Multiple Archiver Appliances on same host, different NICs Daniel Cuneo via Tech-talk
Next: asyn R4-41 available Mark Rivers via Tech-talk
