1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed
From: Heinz Junkes via Tech-talk <[email protected]>
To: "Sintschuk, Michael" <[email protected]>
Date: Mon, 21 Sep 2020 14:47:44 +0200
These might be settings of the dhcp.
Our entries look like this:
rtems-cmdline (129) : /export/epics/felsis3316/iocBoot/iocfelsis3316/st.cmd
host-name (12) : gonzo
tftp-server-name (66) : [email protected]:/export/epics
bootfile-name (67) : /export/epics/felsis3316/bin/RTEMS-beatnik/felsis3316.boot
and the tftp-server-name is used to mount 141.14.128.9:/export/epics as /export/epics
on the mvme2100.
With the MVME6100, you can also define variables in the motorola ppcbug?
If this works with the MVME2100 I don't know anymore.
I found the following here:
https://epics.anl.gov/tech-talk/2013/msg00423.php
MVME6100> gevShow
> mot-script-boot
> tftpGet -c192.168.100.180 -s192.168.100.4 -m255.255.255.0 -d/dev/enet0
> -ftest.boot
> netShut
> go
> mot-/dev/enet0-cipa=192.168.100.180
> mot-/dev/enet0-sipa=192.168.100.4
> mot-/dev/enet0-snma=255.255.255.0
> epics-ntpserver=192.168.100.4
> epics-nfsmount=192.168.100.4:/var/lib/tftpboot:/home
> rtems-client-name=testIoc
> rtems-dns-server=192.168.100.4
> mot-/dev/enet0-file=test.boot
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 21. Sep 2020, at 14:12, Sintschuk, Michael via Tech-talk <[email protected]> wrote:
> Hi Mark,
> I would try this, but I don't know how... Is this a setting in the MVME2100-settings or in the dhcpd.conf of my TFTP/DHCP/NFS-Server?
> -----Ursprüngliche Nachricht-----
> Von: Mark Rivers <[email protected]>
> Gesendet: Montag, 21. September 2020 14:05
> An: Sintschuk, Michael <[email protected]>
> Cc: [email protected]
> Betreff: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed
> Hi Michael,
> Earlier in your startup I see this:
> ***** Initializing NFS *****
> Mount 192.168.99.1:/soft on /soft
> Can you try manually mounting /autosave at that point, and not rely on the autosave module to handle the mount for you?
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
> Sent: Monday, September 21, 2020 4:31 AM
> To: EPICS tech-talk
> Subject: autosave 5-10-1 on RTEMS-4.10.2, mount failed
> Hi all,
> I'm setting up an IOC, BASE-3.15.7 and autosave 5-10-1, on an Motorola board MVME-2100 using RTEMS-4.10.2.
> The comand save_restoreSet_NFSHost fails on it with mount failed: Invalid argument . But my IOC is using nfs to mount it's "st.cmd" file, so I don't know why it is not seeing the autosave folder, that is also exported via NFS.
> Here is my IOC Start-up:
> Copyright Motorola Inc. 1988 - 2004, All Rights Reserved
> PPC5 Debugger/Diagnostics Release Version 1.1 - 08/20/2004 RM04
> COLD Start
> Local Memory Found =02000000 (&33554432)
> MPU Clock Speed =200Mhz
> BUS Clock Speed =67Mhz
> Reset Vector Location  : ROM Bank B
> Mezzanine Configuration: Single-MPU
> Current 60X-Bus Master : MPU0
> Idle MPU(s)            : NONE
> L2Cache:       NONE
> System Memory: 32MB, Parity NOT Enabled (Non-Parity-Memory Detected)
> SelfTest/Boots about to Begin... Press <BREAK> at anytime to Abort ALL
> NetBoot about to Begin... Press <ESC> to Bypass, <SPC> to Continue
> Network Booting from: DEC21143, Controller 0, Device 0
> Device Name: /pci@fec00000/pci1011,19@e,0:0,0
> Loading: epics/iocRtems/iocRtems.boot
> Client IP Address      = 192.168.99.250
> Server IP Address      = 192.168.99.1
> Gateway IP Address     = 0.0.0.0
> Subnet IP Address Mask = 255.255.255.0
> Boot File Name         = epics/iocRtems/iocRtems.boot
> Argument File Name     = /soft/epics/IOC/iocRtems/iocBoot/iocRtems/st.cmd
> Network Boot File load in progress... To abort hit <BREAK>
> Bytes Received =&1183560, Bytes Loaded =&1183560
> Bytes/Second   =&591780, Elapsed Time =2 Second(s)
> Residual-Data Located at: $01F5511C
> Model: Motorola MVME2101          (e2)
> Serial: MOT0BC614E
> Processor/Bus frequencies (Hz): 200003328/66667776
> Time Base Divisor: 4000
> Memory Size: 2000000
> PCI: Probing PCI hardware
> RTEMS 4.x/PPC load:
> Uncompressing the kernel...
> done
> Now booting...
> Welcome to rtems-4.10.2(PowerPC/Generic (classic FPU)/mvme2100) on MVME 2100
> pci : Configuring interrupt routing for 'MVME 2100'
> pci : Device 0:0x00:0 routed to interrupt_line 16
> pci : Device 0:0x0D:0 routed to interrupt_line 23
> pci : Device 0:0x0E:0 routed to interrupt_line 17
> WARNING: unable to allocate page table, keeping DBAT0
> WARNING: unable to setup page tables VME bridge must share PCI space
> OpenPIC Version 1.2 (1 CPUs and 24 IRQ sources) at 0xFCE40000
> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 1
> Overriding NumSources (24) from configuration with 16
> OpenPIC timer frequency is 8333472 Hz
> Universe II PCI-VME bridge detected at 0xFCDFF000, IRQ 23
> Universe Master Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
> 1:    0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
> 2:    0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
> Universe Slave Ports:
> 0:    0xC0000000 0x02000000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> ***** RTEMS Version: rtems-4.10.2(PowerPC/Generic (classic FPU)/mvme2100) *****
> Startup.
> ***** Initializing network *****
> dec2114x : unit 1 base address FCDFEC00.
> dec2114x : driver attached
> dec2114x : driver tasks created
> dec2114x : 00:01:AF:15:AD:97   name 'dc1', io BFDF80, mem FCDFEC00, int 17
> dec2114x: Installing IRQ 17
> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
> Warning: No timezone information, times will be displayed in UTC.
> ***** Starting EPICS application *****
> ## Example RTEMS startup script
> ## You may have to change iocRtems to something else
> ## everywhere it appears in this file
> < envPaths
> epicsEnvSet("IOC","iocRtems")
> epicsEnvSet("TOP","/soft/epics/IOC/iocRtems")
> epicsEnvSet("MODULES","/soft/epics/inst-3.15.7")
> epicsEnvSet("ASYN","/soft/epics/inst-3.15.7/asyn/4-40-1")
> epicsEnvSet("MOTOR","/soft/epics/inst-3.15.7/motor/7-2-1")
> epicsEnvSet("PSEUDOMOTAPPS","/soft/epics/inst-3.15.7/pseudoMotors/1-1")
> epicsEnvSet("SEQLONG","/soft/epics/inst-3.15.7/seqlong-1-0")
> epicsEnvSet("SSCAN","/soft/epics/inst-3.15.7/sscan/2-11-3")
> epicsEnvSet("CALC","/soft/epics/inst-3.15.7/calc/3-7-4")
> epicsEnvSet("AUTOSAVE","/soft/epics/inst-3.15.7/autosave/5-10-1")
> epicsEnvSet("IK342","/soft/epics/inst-3.15.7/IK342")
> epicsEnvSet("EPICS_BASE","/soft/epics/base")
> cd "/soft/epics/IOC/iocRtems"
> ## Register all support components
> dbLoadDatabase("dbd/iocRtems.dbd")
> iocRtems_registerRecordDeviceDriver(pdbbase)
> ## Load record instances
> #dbLoadTemplate("db/iocRtems.substitutions")
> dbLoadRecords("db/iocRtems.db", "user=bl")
> #var drvOms58debug 10
> oms58Setup(11, 0x1000,180,5,2)
> IK342Setup(1,0xC000)
> set_savefile_path("/autosave/iocRtems")
> set_requestfile_path("/autosave/iocRtems")
> save_restoreSet_NFSHost("nfsioc","192.168.99.1")
> Mount nfsioc:/autosave/iocRtems on /autosave/iocRtems
> save_restore: Can't mount '/autosave/iocRtems'
> set_pass0_restoreFile("auto_positions.sav")
> set_pass0_restoreFile("auto_settings.sav")
> #set_pass0_restoreFile("pseudoMotor.sav")
> set_pass1_restoreFile("auto_settings.sav")
> #set_pass1_restoreFile("detectors.sav")
> save_restoreSet_status_prefix("iocRtems:")
> save_restoreSet_DatedBackupFiles(1)
> save_restoreSet_NumSeqFiles(1)
> # Time interval between sequenced backups
> save_restoreSet_SeqPeriodInSeconds(600)
> iocInit
> Starting iocInit
> ## EPICS R3.15.7
> ## EPICS Base built Sep  1 2020
> *** IK342:  Running IK342 Initialization IK342_drv_init ***
> 1 nIK342Cards, 0xc000. baseAddr
> libbspExt - Warning: it seems that MCP support is not available on your CPU
>                     or not implemented by your board. Address probing must
>                     be performed in polling mode with interrupts disabled
> ../drvIK342.c: card 0 present at addr 9FFFC000
> version  FF00
> reboot_restore: entry for file 'auto_positions.sav'
> reboot_restore: Found filename 'auto_positions.sav' in restoreFileList.
> *** restoring from '/autosave/iocRtems/auto_positions.sav' at initHookState 6 (before record/device init) ***
> save_restore: Can't open file '/autosave/iocRtems/auto_positions.sav'.
> save_restore: Trying backup file '/autosave/iocRtems/auto_positions.savB'
> save_restore: Can't open file '/autosave/iocRtems/auto_positions.savB'.
> save_restore: Can't figure out which seq file is most recent,
> save_restore: so I'm just going to start with '/autosave/iocRtems/auto_positions.sav0'.
> save_restore: Trying backup file '/autosave/iocRtems/auto_positions.sav0'
> save_restore: Can't open file '/autosave/iocRtems/auto_positions.sav0'.
> save_restore: Can't find a file to restore from...save_restore: ...last tried '/autosave/iocRtems/auto_positions.sav0'. I give up.
> save_restore: **********************************
> save_restore: Can't open save file.reboot_restore: entry for file 'auto_settings.sav'
> reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
> *** restoring from '/autosave/iocRtems/auto_settings.sav' at initHookState 6 (before record/device init) ***
> save_restore: Can't open file '/autosave/iocRtems/auto_settings.sav'.
> save_restore: Trying backup file '/autosave/iocRtems/auto_settings.savB'
> save_restore: Can't open file '/autosave/iocRtems/auto_settings.savB'.
> save_restore: so I'm just going to start with '/autosave/iocRtems/auto_settings.sav0'.
> save_restore: Trying backup file '/autosave/iocRtems/auto_settings.sav0'
> save_restore: Can't open file '/autosave/iocRtems/auto_settings.sav0'.
> save_restore: Can't find a file to restore from...save_restore: ...last tried '/autosave/iocRtems/auto_settings.sav0'. I give up.
> save_restore: Can't open save file.init_record: card = 0   channel = 0
> init_record: card = 0   channel = 1
> init_record: card = 0   channel = 2
> init_record: card = 0   channel = 3
> *** restoring from '/autosave/iocRtems/auto_settings.sav' at initHookState 7 (after record/device init) ***
> save_restore: Can't open save file.iocRun: All initialization complete
> epicsThreadSleep(10.)
> create_monitor_set("auto_positions.req", 5, "NULL")
> save_restore:readReqFile: unable to open file auto_positions.req. Exiting.
> create_monitor_set("auto_settings.req", 5, "NULL")
> mount failedsave_restore:readReqFile: unable to open file auto_settings.req. Exiting.
> : #create_monitor_set("pseudoMotor.req",5, "NULL")
> Invalid argument#create_monitor_set("detectors.req",5, "NULL")
> #fdbrestore("DMMarm.sav")
> ## Start any sequence programs
> #seq(sncxxx, "user=bl")
> 192.168.99.250> save_restore: Can't connect to all status PV(s)
> save_restore: attempting to remount filesystem
> save_restore: failed to remount '/autosave/iocRtems'
> 192.168.99.250>192.168.99.250>
> This is how my dhcpd.conf for the MVME-2100 looks like (it is OpenSuse Leap 15.1):
>   group {
>    use-host-decl-names on;
>    always-reply-rfc1048 on;
>    server-name bam01;
>    host vmecpu-20 {
>      option host-name iocRtems;
>      option script-name "/soft/epics/IOC/iocRtems/iocBoot/iocRtems/st.cmd";
>      hardware ethernet 00:01:af:15:ad:97;
>      fixed-address 192.168.99.250;
>      filename "epics/iocRtems/iocRtems.boot";
>      next-server 192.168.99.1;
> And this is the exports file-entry for my autosave folder:
> /autosave          172.17.8.0/24(rw,no_subtree_check) 192.168.99.0/24(rw,no_subtree_check)
> The command save_restoreSet_NFSHost("nfsioc","192.168.99.1") is using the CNAME-Record "nfsioc" which is just an alias for my NFS-Server.
> If I set it to the real name of my NFS-Server ("bam01"), it results in the same error: mount failed: Invalid argument
> So what argument am I missing? Does anyone know?
> Regards
> Michael
> Michael Sintschuk
> Bundesanstalt für Materialforschung und -prüfung (BAM)
> 8.5 Mikro-ZfP
> Unter den Eichen 87
> 12205 Berlin
> GERMANY
> P: +49 30 8104-5736 (BESSY, Adlershof)
> P: +49 30 8104-4065 (BAM, Steglitz)
> [email protected]<mailto:[email protected]>
Attachment: smime.p7s
Description: S/MIME cryptographic signature
AW: autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Mark Rivers via Tech-talk
Prev: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Mark Rivers via Tech-talk
Next: AW: autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
