Hi, I'm currently developing an application based on EPICS QT. This toolkit makes things so much easier than using PyQwt which I have used before for the first version of the app. The app reads a picture from a camera, displays the original and does some processing of the image like fouriertransforms, peak finding and fitting etc. To make sure the analyzed pictures and the camera image are in sync, I wanted to read the image data from a PvaClient and display it in an QEImage.Then do all the math and display the results in other QEImage widgets. But unfortunately the set(Pva)Image function is private. One solution would be to implement all the magic math we use as plugins for areaDetector and combine them to the necessary chain. But the machine we use to read the camera is not powerful enough (Odroid XU1) to do that. What would be the performance if we would run the plugins on a separate machine? And how to make sure that they all are in sync? Are there any experiences with such a scenario? Regards J�Dreyer
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
