Subject: Re: Implementing closed loop on EPICS level
From: Guilherme Jovanini Montagner via Tech-talk <[email protected]>
To: "Peterson, Kevin M." <[email protected]>
Date: Tue, 29 Sep 2020 10:55:17 -0300 (BRT)
Hi Kevin
Thank you for your response.
I tried with UEIP = 1, but then it seems to use the motor 1 encoder (which is just the phase value, or open loop value), and not the m11 encoder that I have setup.
Then it disregards the m11 encoder reading
+55 19 99806.9117
+55 19 2517.8911
[email protected]
Labview Certified Developer
----- Mensagem original -----
De: "Peterson, Kevin M." <[email protected]>
Para: "guilherme" <[email protected]>, "tech-talk" <[email protected]>
Enviadas: Terça-feira, 29 de setembro de 2020 10:52:24
Assunto: Re: Implementing closed loop on EPICS level
The motor record issues absolute move command if UEIP and URIP are both
0.  It issues relative move commands if UEIP or URIP is 1.
Kevin
On 9/29/20 8:04 AM, Guilherme Jovanini Montagner via Tech-talk wrote:
> It seems that EPICS is issuing "absolute" movements, instead of
> "relative". Commanded position of 3mm shouldn't result in a target of
> 307200 counts for motor 1, but should issue an incremental movement of
> 0,7mm (in this situation), or +71680 counts, and after that, the DIFF
> field should be considered in order to issue further movements
> What can justify this behaviour? Did we implement this technique correctly?
> Thank you for your attention.
> *Guilherme Jovanini Montagner*
> +55 19 99806.9117
> +55 19 2517.8911
> [email protected]
Re: Implementing closed loop on EPICS level Peterson, Kevin M. via Tech-talk
Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
Prev: Re: Implementing closed loop on EPICS level Peterson, Kevin M. via Tech-talk
Next: Re: Implementing closed loop on EPICS level Peterson, Kevin M. via Tech-talk
