Subject: RE: ADPilatus
To: 'John Dobbins' <[email protected]>
Date: Tue, 6 Oct 2020 15:49:32 +0000
Hi John,
What ThresholdEnergy were you using when Energy was set to 20 keV?  What happens if you set ThresholdEnergy=10 and Energy=20, does that generate a bad flat field?
Prior to R2-3 ADPilatus does not send the energy to camserver, it only sends the ThresholdEnergy.  However, in this case camserver is supposed to automatically set the energy to ThresholdEnergy*2.   If you set ThresholdEnergy=10 camserver should thus set energy to 20, which is equivalent to what I suggested above.  Does that generate a bad flat field?
In the newer version of ADPilatus if you set Energy=0 then the energy it sends to camserver is ThresholdEnergy*2.
If you are getting bad flat fields with reasonable values of Energy and ThresholdEnergy then would seem to be a bug in camserver.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Tuesday, October 6, 2020 10:28 AM
To: [email protected]
Subject: Re: ADPilatus
For the record:
The root of the problem appears to be that the new IOC contains a record (added in R2-7) for the x-ray energy, $(P)$(R)Energy which did not exist in the previous IOC.
The default value for this record is 20 KeV.
This value is used by camserver to generate a flat field correction file. On this Pilatus at least, the value 20 KeV generates a bad flat field correction file.
Thanks to Mark Rivers for his help in debugging this.
John Dobbins
Sent: Friday, October 2, 2020 9:30 AM
Cc: Arthur R. Woll <[email protected]>
Subject: ADPilatus
All,
We have a number of DECTRIS PILATUS detectors for which I recently added an up-to date areaDetector installation.
Previously these detectors were using areaDetector R1-9-1, EPICS Base R3.14.11
I added areaDetector R3-9, EPICS Base R3.15.8
These are the three detector and their tvx versions - note that the 100K  tvx version is different.
PIL 100K   tvx-7.3.13.121212b
PIL 200K  tvx  tvxe-7.4.01-130212
PIL 300K   tvx  tvxe-7.4.01-130212
The 200K and 300K are working fine with the new software, however the 100K is not.
The image from the PIL 100K looks like this:
The first 26 rows appear fine, i.e. pixels typically show tens of counts, then in row 27 pixels with very large numbers and pixels with zero start appearing.
Neither the IOC nor camserver is reporting errors.
The PILATUS 100K continues to work as expected with the old areaDetector installation.
Any ideas on how to proceed?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADPilatus John Dobbins via Tech-talk
RE: ADPilatus Mark Rivers via Tech-talk
Re: ADPilatus John Dobbins via Tech-talk
Prev: Re: ADPilatus John Dobbins via Tech-talk
Next: Re: Sequencer/SNL and PVA? Johnson, Andrew N. via Tech-talk
Next: New releases of ADGenICam, ADAravis, ADSpinnaker, and ADVimba Mark Rivers via Tech-talk
