Subject: RE: MEDM crash
From: "Soliday, Robert T. via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 22 Oct 2020 18:59:32 +0000
The changes in the pull request fixed the problem on Ubuntu. I created a new release of MEDM and closed the pull request.
--Bob
Sent: Thursday, October 22, 2020 1:20 PM
To: Soliday, Robert T. <[email protected]>
Subject: Re: MEDM crash
There is a Pull Request against MEDM on GitHub which solved some issues on Ubuntu that might be causing this, Mark or Pete can you see if that helps?
- Andrew
On Oct 22, 2020, at 10:09 AM, Soliday, Robert T. via Tech-talk <[email protected]> wrote:
I will look into it.
--Bob Soliday
From: Tech-talk <[email protected]> On Behalf Of Siddons, David via Tech-talk
Sent: Thursday, October 22, 2020 9:50 AM
To: EPICS Tech Talk <[email protected]>
Subject: MEDM crash
If, in MEDM edit mode, I try to change the numeric format for a field (say, from decimal to engineering), MEDM crashes with:
*** stack smashing detected ***: terminated
Aborted
This is on Ubuntu 20.04, MEDM Version 3.1.15, EPICS 3.15.6
Any ideas?
Pete.
Complexity comes for free, simplicity you have to work for.
Re: MEDM crash Siddons, David via Tech-talk
RE: MEDM crash Soliday, Robert T. via Tech-talk
Re: MEDM crash Johnson, Andrew N. via Tech-talk
Prev: Re: MEDM crash Mark Rivers via Tech-talk
Next: Re: Seeking config advice for smarAct MCS controller Juliane Reinhardt via Tech-talk
Prev: Re: MEDM crash Siddons, David via Tech-talk
Next: Re: MEDM crash Siddons, David via Tech-talk
