Subject: Re: MEDM crash
From: "Siddons, David via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Soliday, Robert T." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 22 Oct 2020 19:56:36 +0000
Thanks, Bob. I'll give it a shot.
Pete.
From: Tech-talk <[email protected]> on behalf of Soliday, Robert T. via Tech-talk <[email protected]>
Sent: Thursday, October 22, 2020 2:59 PM
To: Johnson, Andrew N. <[email protected]>
Subject: RE: MEDM crash
The changes in the pull request fixed the problem on Ubuntu. I created a new release of MEDM and closed the pull request.
--Bob
Sent: Thursday, October 22, 2020 1:20 PM
To: Soliday, Robert T. <[email protected]>
There is a Pull Request against MEDM on GitHub which solved some issues on Ubuntu that might be causing this, Mark or Pete can you see if that helps?
- Andrew
On Oct 22, 2020, at 10:09 AM, Soliday, Robert T. via Tech-talk <[email protected]> wrote:
I will look into it.
--Bob Soliday
From: Tech-talk <[email protected]> On Behalf Of Siddons, David via Tech-talk
Sent: Thursday, October 22, 2020 9:50 AM
To: EPICS Tech Talk <[email protected]>
Subject: MEDM crash
If, in MEDM edit mode, I try to change the numeric format for a field (say, from decimal to engineering), MEDM crashes with:
*** stack smashing detected ***: terminated
Aborted
This is on Ubuntu 20.04, MEDM Version 3.1.15, EPICS 3.15.6
Any ideas?
Pete.
Complexity comes for free, simplicity you have to work for.
MEDM crash Siddons, David via Tech-talk
RE: MEDM crash Soliday, Robert T. via Tech-talk
Re: MEDM crash Johnson, Andrew N. via Tech-talk
Prev: Re: Seeking config advice for smarAct MCS controller Juliane Reinhardt via Tech-talk
Next: Re: MEDM crash Johnson, Andrew N. via Tech-talk
Prev: RE: MEDM crash Soliday, Robert T. via Tech-talk
Next: Thank you! Maren Purves via Tech-talk
