On Oct 22, 2020, at 1:54 PM, Mark Rivers <[email protected]> wrote:
That PR builds OK on Centos 7, but it fails to build on Ubuntu 18. I see the same failure on Ubuntu 18 with the MEDM_3_1_14 tag.
TahoeU18:/corvette/usr/local/epics/extensions_new/src/medm_fix> make
make -C ./printUtils install
make[1]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils'
make -C O.linux-x86_64-ub18 -f ../Makefile TOP=../../../.. \
T_A=linux-x86_64-ub18 install
make[2]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils/O.linux-x86_64-ub18'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include
-I/corvette/usr/local/epics/base/include/compiler/gcc -I/corvette/usr/local/epics/base/include/os/Linux -I/corvette/usr/local/epics/base/include -I../../../../include -I -MM -MF xwd2ps.d ../xwd2ps.c
cc1: error: to generate dependencies you must specify either -M or -MM
As Bob pointed out you have an empty include path in your build. The last
-I option there was eating up the -MM which explains the error message, so one of your extensions config variables was probably empty.
- Andrew
Complexity comes for free, simplicity you have to work for.
- RE: MEDM crash Mark Rivers via Tech-talk
- MEDM crash Siddons, David via Tech-talk
- RE: MEDM crash Soliday, Robert T. via Tech-talk
- Re: MEDM crash Johnson, Andrew N. via Tech-talk
- Re: MEDM crash Mark Rivers via Tech-talk
Re: MEDM crash Siddons, David via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
