1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: MEDM crash
To: "'Johnson, Andrew N.'" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 22 Oct 2020 20:22:18 +0000
Ø  As Bob pointed out you have an empty include path in your build. The last -I option there was eating up the -MM which explains the error message, so one of your extensions config variables was probably empty.
I solved that.  I was missing this file that needs to define X11_LIB and MOTIF_LIB:
extensions/configure/os/CONFIG_SITE.linux-x86_64-ub18.linux-x86_64-ub18
However, now I get this error:
   -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXp -lXmu -lX11 -lXext   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lXp
collect2: error: ld returned 1 exit status
/corvette/usr/local/epics/base/configure/RULES_BUILD:212: recipe for target 'medm' failed
I have Googled to see what package provides libXp.so on Ubuntu 18, and I can’t find it.  Others have the same problem.
Pete and Bob how did you install libXp.so?
Sent: Thursday, October 22, 2020 3:14 PM
Cc: Soliday, Robert T. <[email protected]>; EPICS tech-talk <[email protected]>
Subject: Re: MEDM crash
On Oct 22, 2020, at 1:54 PM, Mark Rivers <[email protected]> wrote:
That PR builds OK on Centos 7, but it fails to build on Ubuntu 18.  I see the same failure on Ubuntu 18 with the MEDM_3_1_14 tag.
TahoeU18:/corvette/usr/local/epics/extensions_new/src/medm_fix> make
make -C ./printUtils install
make[1]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils'
make -C O.linux-x86_64-ub18 -f ../Makefile TOP=../../../.. \
   T_A=linux-x86_64-ub18 install
make[2]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils/O.linux-x86_64-ub18'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I/corvette/usr/local/epics/base/include/compiler/gcc -I/corvette/usr/local/epics/base/include/os/Linux -I/corvette/usr/local/epics/base/include   -I../../../../include       -I    -MM -MF xwd2ps.d  ../xwd2ps.c
cc1: error: to generate dependencies you must specify either -M or -MM
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: MEDM crash Johnson, Andrew N. via Tech-talk
MEDM crash Siddons, David via Tech-talk
RE: MEDM crash Soliday, Robert T. via Tech-talk
Re: MEDM crash Mark Rivers via Tech-talk
Prev: Re: MEDM crash Johnson, Andrew N. via Tech-talk
Next: Re: MEDM crash Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
