1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 26 Oct 2020 18:02:34 +0100
Thanks a lot Matt,
That unique ID is in addition to the RS-485 address, like a transaction counter.
It looks like any single controller can cope with multiple commands being received at high speed, and will send the responses in some (any) order, using the unique ID from the respective command in the replies for the master to tell them apart.
This "parallel" mode probably does not apply as StreamDevice/Asyn is serializing the protocols and waits for the response before sending the next request.
Thanks again,
~Ralph
AW: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Zimoch Dirk (PSI) via Tech-talk
Experiences using RS-485 Multi-Drop with StreamDevice? Ralph Lange via Tech-talk
RE: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Pearson, Matthew R. via Tech-talk
Prev: RE: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Pearson, Matthew R. via Tech-talk
Next: Read PV value Attributes XML Douglas Araujo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: AW: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Zimoch Dirk (PSI) via Tech-talk
