1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Read PV value Attributes XML
From: Douglas Araujo via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 26 Oct 2020 20:36:33 -0300
I'm trying to set some attributes using XML, and I am had problem with some pvs.
Example XML file:
<?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
    xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
    <Attribute name="NumExposures"  	  type="EPICS_PV"    source="CAT:S:cam1:NumExposures_RBV"       datatype="DBR_NATIVE"     description="Number of exposures manufacturer"/>
    <Attribute name="m1_velocity"  	  type="EPICS_PV"    source="CAT:S:m1.VELO"       		datatype="DBR_NATIVE"     description="Motor 1 Velocity"/>
    <Attribute name="photodiode"  	  type="EPICS_PV"    source="CAT:C:RIO03:0215B:ai1       	datatype="DBR_NATIVE"     description="BIM01 - Photodiode"/>
</Attributes>
The two first lines and works fine. The first is a PV from simDetector IOC, (The same IOC where I'm using the HDF5Plugin  and using the XML file). The second is a motorRecord Simulated IOC, that is running in the same host that first ioc.
But, the last one, is returning the value "nan". This specific IOC that provide this PV is running in another host. However, I can read the value using caget:
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ caget CAT:C:RIO03:9215B:ai1
CAT:C:RIO03:9215B:ai1          0.000247466
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ cainfo CAT:C:RIO03:9215B:ai1
    State:            connected
    Host:             s-cat-c-rio03.abtlus.org.br:5064
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
I'm using the 3.3.1 ADCore Version.
I read the documentation and saw that this is a behavior when the pv is not connected. But my pv is connected. Need I set some parameter on ioc to get PV from another host ? Or someone have any ideas about this behaivor ??
Regards.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Read PV value Attributes XML Hugo Slepicka via Tech-talk
RE: Read PV value Attributes XML Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Ralph Lange via Tech-talk
Next: Re: Read PV value Attributes XML Hugo Slepicka via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: AW: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Zimoch Dirk (PSI) via Tech-talk
