Subject: Re: Read PV value Attributes XML
From: Hugo Slepicka via Tech-talk <[email protected]>
To: Douglas Araujo <[email protected]>
Date: Mon, 26 Oct 2020 16:39:06 -0700
I noticed that the PV you mentioned is not working seems to be missing a closing ".
Was this an artifact of the copy/paste or really it is missing the quote?
Cheers,
Hugo
On Mon, Oct 26, 2020 at 4:37 PM Douglas Araujo via Tech-talk <[email protected]> wrote:
I'm trying to set some attributes using XML, and I am had problem with some pvs.
Example XML file:
<?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
    xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
    <Attribute name="NumExposures"  	  type="EPICS_PV"    source="CAT:S:cam1:NumExposures_RBV"       datatype="DBR_NATIVE"     description="Number of exposures manufacturer"/>
    <Attribute name="m1_velocity"  	  type="EPICS_PV"    source="CAT:S:m1.VELO"       		datatype="DBR_NATIVE"     description="Motor 1 Velocity"/>
    <Attribute name="photodiode"  	  type="EPICS_PV"    source="CAT:C:RIO03:0215B:ai1       	datatype="DBR_NATIVE"     description="BIM01 - Photodiode"/>
</Attributes>
The two first lines and works fine. The first is a PV from simDetector IOC, (The same IOC where I'm using the HDF5Plugin  and using the XML file). The second is a motorRecord Simulated IOC, that is running in the same host that first ioc.
But, the last one, is returning the value "nan". This specific IOC that provide this PV is running in another host. However, I can read the value using caget:
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ caget CAT:C:RIO03:9215B:ai1
CAT:C:RIO03:9215B:ai1          0.000247466
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ cainfo CAT:C:RIO03:9215B:ai1
    State:            connected
    Host:             s-cat-c-rio03.abtlus.org.br:5064
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
I'm using the 3.3.1 ADCore Version.
I read the documentation and saw that this is a behavior when the pv is not connected. But my pv is connected. Need I set some parameter on ioc to get PV from another host ? Or someone have any ideas about this behaivor ??
Regards.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Read PV value Attributes XML Douglas Henrique C. de Araújo via Tech-talk
Read PV value Attributes XML Douglas Araujo via Tech-talk
Prev: Read PV value Attributes XML Douglas Araujo via Tech-talk
Next: Re: Read PV value Attributes XML Douglas Henrique C. de Araújo via Tech-talk
