Subject: RE: Read PV value Attributes XML
To: 'Douglas Araujo' <[email protected]>
Date: Tue, 27 Oct 2020 14:55:43 +0000
Ø  One question, when the value is undefined (same condition was before), shouldn't IOC use the EPICS_CA_ADDR_LIST set in the bash?
Yes, it does do that.  Here is proof:
This is looking at the shell value:
corvette:CARS/iocBoot/ioc13bmc_DAC_XPS>echo $EPICS_CA_ADDR_LIST
164.54.160.255 10.100.160.255
This is the value in the IOC.  This IOC startup script does not set EPICS_CA_ADDR_LIST
epics> epicsPrtEnvParams
EPICS_CA_ADDR_LIST: 164.54.160.255 10.100.160.255
So if your IOC is not inheriting the EPICS_CA_ADDR_LIST value then I suspect that is due to the way you are starting the IOC so it does not inherit the values from your .bash_profile, or something is resetting it.
Sent: Tuesday, October 27, 2020 8:26 AM
Cc: [email protected]
Subject: Re: Read PV value Attributes XML
Hi Mark,
my epicsPrtEnvParams output
epicsPrtEnvParams
EPICS_CA_ADDR_LIST is undefined
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: YES
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CA_MAX_ARRAY_BYTES: 9999999999
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_BUILD_COMPILER_CLASS: gcc
EPICS_BUILD_OS_CLASS: Linux
EPICS_BUILD_TARGET_ARCH: linux-x86_64
EPICS_TIMEZONE: CUS::360:031102:110402
EPICS_TS_NTP_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_CMD_PROTO_PORT is undefined
EPICS_AR_PORT: 7002
IOCSH_PS1: epics>
IOCSH_HISTSIZE: 50
Now I put the addr list in the ioc boot file, and works fine...
epicsEnvSet("EPICS_CA_ADDR_LIST", "10.31.34.17 10.31.34.40 10.31.33.20 10.31.34.45 10.31.34.29 10.31.34.28 10.31.34.25 10.31.34.52 10.31.34.49 10.0.38.46:60000 10.0.38.59:60000 10.31.34.55 10.31.34.66 10.31.31.16")
Thanks
Regards
Em 26/10/2020 20:57, Mark Rivers escreveu:
One possibility is that one of the scripts that is starting your areaDetector IOC is setting EPICS_CA_ADDR_LIST in such a way that the remote IOC is not reachable for that areaDetector IOC process.  That could explain why caget works for another process but not for the areaDetector IOC.
At the areaDetector IOC prompt type this command to see all of the CA settings:
epicsPrtEnvParams
areaDetector can read PVs from other IOCs with no problem.  The attribute files for my detectors are getting PVs from many IOCs.
From: Tech-talk <[email protected]> On Behalf Of Douglas Araujo via Tech-talk
Sent: Monday, October 26, 2020 6:37 PM
To: [email protected]
Subject: Read PV value Attributes XML
I'm trying to set some attributes using XML, and I am had problem with some pvs.
Example XML file:
<?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
    xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
    <Attribute name="NumExposures"       type="EPICS_PV"    source="CAT:S:cam1:NumExposures_RBV"       datatype="DBR_NATIVE"     description="Number of exposures manufacturer"/>
    <Attribute name="m1_velocity"        type="EPICS_PV"    source="CAT:S:m1.VELO"                 datatype="DBR_NATIVE"     description="Motor 1 Velocity"/>
    <Attribute name="photodiode"         type="EPICS_PV"    source="CAT:C:RIO03:0215B:ai1          datatype="DBR_NATIVE"     description="BIM01 - Photodiode"/>
</Attributes>
The two first lines and works fine. The first is a PV from simDetector IOC, (The same IOC where I'm using the HDF5Plugin  and using the XML file). The second is a motorRecord Simulated IOC, that is running in the same host that first ioc.
But, the last one, is returning the value "nan". This specific IOC that provide this PV is running in another host. However, I can read the value using caget:
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ caget CAT:C:RIO03:9215B:ai1
CAT:C:RIO03:9215B:ai1          0.000247466
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ cainfo CAT:C:RIO03:9215B:ai1
    State:            connected
    Host:             s-cat-c-rio03.abtlus.org.br:5064
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
I'm using the 3.3.1 ADCore Version.
I read the documentation and saw that this is a behavior when the pv is not connected. But my pv is connected. Need I set some parameter on ioc to get PV from another host ? Or someone have any ideas about this behaivor ??
Regards.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Read PV value Attributes XML Douglas Araujo via Tech-talk
RE: Read PV value Attributes XML Mark Rivers via Tech-talk
Re: Read PV value Attributes XML Douglas Araujo via Tech-talk
Prev: Re: Read PV value Attributes XML Douglas Araujo via Tech-talk
Next: Re: Read PV value Attributes XML Johnson, Andrew N. via Tech-talk
