Subject: Re: Build system prepending $(TOP) to make path on win32-x86
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Daykin, Evan" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 27 Oct 2020 18:19:33 +0000
Hi Evan,
I’m not an MSYS user myself (I’m not keen on the way it uses its own /c/… paths) but there are other people here with more experience of using it who I hope will respond (I think they recommend MSYS2 now though, do you know the difference?). In the meantime some basic questions to provide us with a bit more information:
What version of Base did you install?
Can you try running these commands in your test2 directory and post the results please:
make —version
perl -v
make show-makefiles
make PRINT.MAKE
make PRINT.CONVERTRELEASE
make PRINT.RELEASE_TOPS
- Andrew
On Oct 27, 2020, at 11:49 AM, Daykin, Evan via Tech-talk <[email protected]> wrote:
Good Afternoon,
I am attempting to get the EPICS build system working on win32-x86 architecture. I have successfully built base, but I get some strange behavior after trying to build an IOC created via makeBaseApp.pl. Here is what I run:
mkdir test2
cd test2
makeBaseApp.pl –t ioc test
makeBaseApp.pl –i –t ioc test
directory structure is now:
-configure
-iocBoot
-testApp
Makefile
configure/RELEASE points at the correct EPICS_BASE
Now, when I try running make, the following output results:
PS C:\Users\daykin\scratch\test2> make
Can't open perl script ".": Permission denied
/c/Users/daykin/scratch/test2/"C:/MinGW/msys/1.0/bin/make.exe" -C ./configure install
/bin/sh: /c/Users/daykin/scratch/test2/C:/MinGW/msys/1.0/bin/make.exe: No such file or directory
make.exe": *** [configure.install] Error 127
See the third line: Somehow, my $(TOP) is prepended to the location of make. It should just be running “C:/MinGW/msys/1.0/bin/make.exe”. I’m not sure if this is also the cause of “Can’t open perl script ‘.’”, which also seems strange.
Is there something I’m missing here?
-Evan
Complexity comes for free, simplicity you have to work for.
RE: Build system prepending $(TOP) to make path on win32-x86 Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
Re: Build system prepending $(TOP) to make path on win32-x86 Ralph Lange via Tech-talk
Build system prepending $(TOP) to make path on win32-x86 Daykin, Evan via Tech-talk
Prev: vscode extension for EPICS Victor Nadot via Tech-talk
Next: RE: Build system prepending $(TOP) to make path on win32-x86 Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
Prev: Build system prepending $(TOP) to make path on win32-x86 Daykin, Evan via Tech-talk
