Subject: Re: Building ADVimba on Raspberry Pi
To: "Kinder, Steve (STFC,DL,TECH)" <[email protected]>
Date: Wed, 28 Oct 2020 17:21:19 +0000
Hi Steve,
ADVimba does not come with the libVimbaC.so, etc. files for linux-arm.  But those library  files are available from AVT, so you could copy them over and it should build.  If it works we could add them to the distribution.
From: Tech-talk <[email protected]> on behalf of Kinder, Steve (STFC,DL,TECH) via Tech-talk <[email protected]>
Sent: Wednesday, October 28, 2020 11:59 AM
To: EPICS Tech Talk
Subject: Building ADVimba on Raspberry Pi
I get the following error when trying to build ADVimba on a Raspberry Pi. Any suggestions as to how to get around this would be appreciated whilst I continue trying.
Thanks
Steve
/usr/bin/ar -rc    libVimbaCPP.a     AncillaryData.o BaseFeature.o BasicLockable.o BoolFeature.o Camera.o Clock.o CommandFeature.o Condition.o ConditionHelper.o DefaultCameraFactory.o EnumEntry.o EnumFeature.o FeatureContainer.o Feature.o FileLogger.o FloatFeature.o Frame.o FrameHandler.o Interface.o IntFeature.o Mutex.o MutexGuard.o RawFeature.o Semaphore.o StringFeature.o VimbaSystem.o
/usr/bin/ranlib libVimbaCPP.a
make[2]: *** No rule to make target '../../lib/linux-arm/libVimbaC.a', needed by 'libVimbaCPP.so'.  Stop.
make[2]: Leaving directory '/home/controls/prod/R7.0.3.1/support/ADVimba/1-2dl1/vimbaSupportCPP/O.linux-arm'
make[1]: *** [/home/epics/R7.0.3.1/base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
make[1]: Leaving directory '/home/controls/prod/R7.0.3.1/support/ADVimba/1-2dl1/vimbaSupportCPP'
make: *** [/home/epics/R7.0.3.1/base/configure/RULES_DIRS:84: vimbaSupportCPP.install] Error 2
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Re: Building ADVimba on Raspberry Pi Kinder, Steve (STFC,DL,TECH) via Tech-talk
Prev: Re: Building ADVimba on Raspberry Pi Johnson, Andrew N. via Tech-talk
Next: Re: ca-gateway and PUTACKS Johnson, Andrew N. via Tech-talk
Next: Re: Building ADVimba on Raspberry Pi Kinder, Steve (STFC,DL,TECH) via Tech-talk
