Subject: Building ADVimba on Raspberry Pi
From: "Kinder, Steve \(STFC,DL,TECH\) via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 28 Oct 2020 16:59:22 +0000
I get the following error when trying to build ADVimba on a Raspberry Pi. Any suggestions as to how to get around this would be appreciated whilst I continue trying.
Thanks
Steve
/usr/bin/ar -rc    libVimbaCPP.a     AncillaryData.o BaseFeature.o BasicLockable.o BoolFeature.o Camera.o Clock.o CommandFeature.o Condition.o ConditionHelper.o DefaultCameraFactory.o EnumEntry.o EnumFeature.o FeatureContainer.o Feature.o FileLogger.o FloatFeature.o Frame.o FrameHandler.o Interface.o IntFeature.o Mutex.o MutexGuard.o RawFeature.o Semaphore.o StringFeature.o VimbaSystem.o
/usr/bin/ranlib libVimbaCPP.a
make[2]: *** No rule to make target '../../lib/linux-arm/libVimbaC.a', needed by 'libVimbaCPP.so'.  Stop.
make[2]: Leaving directory '/home/controls/prod/R7.0.3.1/support/ADVimba/1-2dl1/vimbaSupportCPP/O.linux-arm'
make[1]: *** [/home/epics/R7.0.3.1/base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
make[1]: Leaving directory '/home/controls/prod/R7.0.3.1/support/ADVimba/1-2dl1/vimbaSupportCPP'
make: *** [/home/epics/R7.0.3.1/base/configure/RULES_DIRS:84: vimbaSupportCPP.install] Error 2
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Re: Building ADVimba on Raspberry Pi Johnson, Andrew N. via Tech-talk
Re: Building ADVimba on Raspberry Pi Mark Rivers via Tech-talk
Prev: Re: EPICS IOC and its client application with ONLY IPv6 Johnson, Andrew N. via Tech-talk
Next: Re: Building ADVimba on Raspberry Pi Johnson, Andrew N. via Tech-talk
Prev: EPICS core java 7.0.7 release Shroff, Kunal via Tech-talk
