Subject: |
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" |
Jeong Han Lee via Tech-talk <[email protected]> |
To: |
"Manoussakis, Adamandios" <[email protected]> |
Cc: |
tech-talk <[email protected]> |
Date: |
Wed, 28 Oct 2020 11:10:49 -0700 |
I have an obligation to reply to this email. I will come back to you
in more detail later.
Meanwhile, you may check the following things:
1) firewall
2) selinux
3) mysql db
4) several log files will be located in mgmt,etl,engine,retrieval/logs
Ant this repository was designed to help any users to set it easily,
and it is not for production. Technically, it doesn't matter, but for
the production you should consider many configurations in great details.
HTH,
Han
On Tue, Oct 27, 2020 at 11:45 PM Manoussakis, Adamandios via Tech-talk
<[email protected]> wrote:
> Hello All,
> I have started to build the epics archiver appliance following Hans repo at https://github.com/jeonghanlee/epicsarchiverap-env. Everything seems to be working great with the application and I am able to access the archiver web application just fine. I start up a basic softIoc with a couple PVs and my pyDM widget is able to control and access them just fine but I cannot get them to be archived by the appliance. I can also use caget/camonitor/caput without any issue to manipulate the softIoc. I saw another post about checking the ports in the appliances.xml but that seems to be correct from what I can tell. I tried to look through the logs in /opt/epicsarchiverap/engine mgmt etl retrieval but I didnt see any errors that stood out. I am not sure if its a connection issue with the ca and the archiver or a record thing I am missing but any advice would be helpful. I have tried using ca://calc:a , calc:a but no luck getting it to archive.
> appliances.xml
> <appliances>
> <appliance>
> <identity>appliance0</identity>
> <cluster_inetport>localhost:16670</cluster_inetport>
> <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
> <engine_url>http://localhost:17666/engine/bpl</engine_url>
> <etl_url>http://localhost:17667/etl/bpl</etl_url>
> <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
> <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
> </appliance>
> </appliances>
> also checked the conf file for archappl
> JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
> JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
> CATALINA_HOME="/usr/share/tomcat9"
> CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
> ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
> ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
> ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
> ARCHAPPL_MYIDENTITY="appliance0"
> ARCHAPPL_STORAGE_TOP="/arch"
> ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
> ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
> ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
> Example Record for one of the PVs
> record(ao,"$(INST):a"){
> field(DESC,"Input A")
> field(DTYP,"Soft Channel")
> field(PREC,1)
> field(DRVH,10)
> field(HOPR,10)
> field(VAL,0)
> field(LOPR,-10)
> field(DRVL,-10)
> field(UDF,1)
> field(FLNK,"$(INST):sum")
> field(ADEL,0)
> field(MDEL,0)
> Thanks
- Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
- Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Re: ca-gateway and PUTACKS Johnson, Andrew N. via Tech-talk
Re: Read PV value Attributes XML Douglas Araujo via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
