Subject: Re: [EXTERNAL] Re: Read PV value Attributes XML
From: "Hartman, Steven via Tech-talk" <[email protected]>
To: Douglas Araujo <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 28 Oct 2020 20:38:48 +0000
> On Oct 28, 2020, at 4:13 PM, Douglas Araujo via Tech-talk <[email protected]> wrote:
> when I run as sudo the ours script to start the IOC (that uses procServer), it don't get the root environment variables. So, I configured the script to get the local user environment variables when call the script as sudo
Generally, you should not run the IOC with root privileges as that opens up potential security risks. More typically, a service account is created specifically to run the IOC with privileges appropriate for what the IOC needs to access. The system service responsible for starting the IOC can su to the IOC account, set appropriate env variables, and start the IOC via procServer or otherwise.
Steven Hartman
[email protected]
Read PV value Attributes XML Douglas Araujo via Tech-talk
RE: Read PV value Attributes XML Mark Rivers via Tech-talk
Re: Read PV value Attributes XML Douglas Araujo via Tech-talk
Re: Read PV value Attributes XML Johnson, Andrew N. via Tech-talk
Prev: Re: Read PV value Attributes XML Douglas Araujo via Tech-talk
Next: Re: EPICS IOC and its client application with ONLY IPv6 Jeong Han Lee via Tech-talk
Next: Reg multi monitor GUI in CSS Himanshu Tyagi via Tech-talk
