Subject: |
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" |
"Manoussakis, Adamandios via Tech-talk" <[email protected]> |
To: |
"Wang, Lin" <[email protected]> |
Cc: |
tech-talk <[email protected]> |
Date: |
Thu, 29 Oct 2020 00:53:46 +0000 |
Hi Lin,
currently I have in my ~/.profile
export EPICS_CA_AUTO_ADDR_LIST=YES
export EPICS_CA_ADDR_LIST=localhost
do I need to have these located in the archappl.conf instead of being exported through profile, seems like the scripts do the same thing at the end of the day just export the env variables?
Thanks
Hello,
You may also want to make sure the EPICS-related environment variable (EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST) loaded by Archiver Appliance is correct, probably in your case "localhost" should be in the EPICS_CA_ADDR_LIST address list.
For example, in the Archiver Appliance single machine installation sample, the following line locates in sampleStartup.sh file, and setEPICSEnv.sh file sets the two environment variables above. In your case this line can be in the conf file,
source /opt/local/setEPICSEnv.sh
Lin
-----Original Messages-----
From:"Manoussakis, Adamandios via Tech-talk" <[email protected]>
Sent Time:2020-10-28 14:45:17 (Wednesday)
To: tech-talk <[email protected]>
Cc:
Subject: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
Hello All,
I have started to build the epics archiver appliance following Hans repo at
https://github.com/jeonghanlee/epicsarchiverap-env. Everything seems to be working great with the application and I am able to access the archiver web application just fine. I start up a basic softIoc with a couple PVs and my pyDM widget is able to control
and access them just fine but I cannot get them to be archived by the appliance. I can also use caget/camonitor/caput without any issue to manipulate the softIoc. I saw another post about checking the ports in the appliances.xml but that seems to be correct
from what I can tell. I tried to look through the logs in /opt/epicsarchiverap/engine mgmt etl retrieval but I didnt see any errors that stood out. I am not sure if its a connection issue with the ca and the archiver or a record thing I am missing but any
advice would be helpful. I have tried using ca://calc:a , calc:a but no luck getting it to archive.
appliances.xml
<appliances>
<appliance>
<identity>appliance0</identity>
<cluster_inetport>localhost:16670</cluster_inetport>
<mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
<engine_url>http://localhost:17666/engine/bpl</engine_url>
<etl_url>http://localhost:17667/etl/bpl</etl_url>
<retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
<data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
</appliance>
</appliances>
also checked the conf file for archappl
JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
CATALINA_HOME="/usr/share/tomcat9"
CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
ARCHAPPL_MYIDENTITY="appliance0"
ARCHAPPL_STORAGE_TOP="/arch"
ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
Example Record for one of the PVs
record(ao,"$(INST):a"){
field(DESC,"Input A")
field(DTYP,"Soft Channel")
field(PREC,1)
field(DRVH,10)
field(HOPR,10)
field(VAL,0)
field(LOPR,-10)
field(DRVL,-10)
field(UDF,1)
field(FLNK,"$(INST):sum")
field(ADEL,0)
field(MDEL,0)
Thanks
- Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
- Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
- Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Wang, Lin via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
