Subject: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: "Wang, Lin" <[email protected]>
Date: Thu, 29 Oct 2020 01:00:49 +0000
IT WORKS!  Just need to track down which change made it work now haha.  But it has something to do with either changing the AUTO_ADDR back to NO or adding the env variables to the archappl.conf file.  Will update once I figure out which one it is.  But thank you both for helping me debug it was extremely helpful!
Sent: Wednesday, October 28, 2020 5:53 PM
To: Wang, Lin <[email protected]>
Hi Lin,
currently I have in my ~/.profile
export EPICS_CA_AUTO_ADDR_LIST=YES
export EPICS_CA_ADDR_LIST=localhost
do I need to have these located in the archappl.conf instead of being exported through profile, seems like the scripts do the same thing at the end of the day just export the env variables?
Thanks
Sent: Wednesday, October 28, 2020 5:41 PM
To: Manoussakis, Adamandios <[email protected]>
Hello,
You may also want to make sure the EPICS-related environment variable (EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST) loaded by Archiver Appliance is correct, probably in your case "localhost" should be in the EPICS_CA_ADDR_LIST address list.
For example, in the Archiver Appliance single machine installation sample, the following line locates in sampleStartup.sh file, and setEPICSEnv.sh file sets the two environment variables above. In your case this line can be in the conf file,
source /opt/local/setEPICSEnv.sh
Lin
-----Original Messages-----
From:"Manoussakis, Adamandios via Tech-talk" <[email protected]>
Sent Time:2020-10-28 14:45:17 (Wednesday)
To: tech-talk <[email protected]>
Cc:
Subject: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
Hello All,
I have started to build the epics archiver appliance following Hans repo at https://github.com/jeonghanlee/epicsarchiverap-env.  Everything seems to be working great with the application and I am able to access the archiver web application just fine.  I start up a basic softIoc with a couple PVs and my pyDM widget is able to control and access them just fine but I cannot get them to be archived by the appliance.  I can also use caget/camonitor/caput without any issue to manipulate the softIoc.   I saw another post about checking the ports in the appliances.xml but that seems to be correct from what I can tell.  I tried to look through the logs in /opt/epicsarchiverap/engine mgmt etl retrieval but I didnt see any errors that stood out.  I am not sure if its a connection issue with the ca and the archiver or a record thing I am missing but any advice would be helpful.  I have tried using ca://calc:a , calc:a but no luck getting it to archive.
appliances.xml
<appliances>
   <appliance>
     <identity>appliance0</identity>
     <cluster_inetport>localhost:16670</cluster_inetport>
     <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://localhost:17666/engine/bpl</engine_url>
     <etl_url>http://localhost:17667/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
   </appliance>
</appliances>
also checked the conf file for archappl
JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
CATALINA_HOME="/usr/share/tomcat9"
CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
ARCHAPPL_MYIDENTITY="appliance0"
ARCHAPPL_STORAGE_TOP="/arch"
ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
Example Record for one of the PVs
record(ao,"$(INST):a"){
field(DESC,"Input A")
field(DTYP,"Soft Channel")
field(PREC,1)
field(DRVH,10)
field(HOPR,10)
field(VAL,0)
field(LOPR,-10)
field(DRVL,-10)
field(UDF,1)
field(FLNK,"$(INST):sum")
field(ADEL,0)
field(MDEL,0)
Thanks
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Wang, Lin via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Prev: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Next: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
