Subject: Re: Error in dbd/HPE3631Atest.dbd" line 12090
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: lynn <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 29 Oct 2020 16:46:43 +0000
Hi Lynn,
Thank-you for including all the information you did in your message, it lets me understand your setup.
The version of the instructions you point to are from an Asyn release made in February 2013, are you actually using version 4-21 of Asyn? If not, please find the right version of the HowTo-StreamDevice document linked from this page which is the current home page for the Asyn module. There have been some subtle changes to those instructions for newer releases, in particular to the list of .dbd files that you have to add to your IOC’s Makefile and I suspect that using the right set of instructions will solve your problem. If not, please reply to this list again and include the contents of that Makefile.
- Andrew
On Oct 29, 2020, at 8:45 AM, lynn via Tech-talk <[email protected]> wrote:
Hi all,
    I use the ubuntu  20.04. epics 3.15.7.
    I met the error when I execuate ./st.cmd.
dbLoadDatabase "dbd/HPE3631Atest.dbd"
Declaration of recordtype(scalcout) preceeded full definition.
Error at or before "}" in file "dbd/HPE3631Atest.dbd" line 12090
HPE3631Atest_registerRecordDeviceDriver pdbbase
registerRecordDeviceDriver failed ao
registerRecordDeviceDriver failed fanout
registerRecordDeviceDriver failed histogram
registerRecordDeviceDriver failed longin
registerRecordDeviceDriver failed sel
registerRecordDeviceDriver failed stringoutout
registerRecordDeviceDriver failed permissive
registerRecordDeviceDriver failed printf
    First error,  line 12090 in file "dbd/HPE3631Atest.dbd" was these,
    field(INX, DBF_ULONG) {
        interest(3)
        special(SPC_NOMOD)
        prompt("Compressed Array Inx")
recordtype(scalcout) {
}                                        #line 12090
device(scalcout, INST_IO, devscalcoutStream, "stream")
recordtype(stringout) {
    %#include "epicsTypes.h"
    %#include "link.h"
       The record of scalcout was empty and it's a readonly file.
       I tried it twice in three days, so I come here for some help.
Lynn
Complexity comes for free, simplicity you have to work for.
Error in dbd/HPE3631Atest.dbd" line 12090 lynn via Tech-talk
Prev: Re: get alias "real" name Johnson, Andrew N. via Tech-talk
Next: Re: Build system prepending $(TOP) to make path on win32-x86 Ralph Lange via Tech-talk
Prev: Error in dbd/HPE3631Atest.dbd" line 12090 lynn via Tech-talk
Next: get alias "real" name Alfio Rizzo via Tech-talk
