Subject: Re: get alias "real" name
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Alfio Rizzo <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 29 Oct 2020 16:27:25 +0000
Hi Alfio,
On Oct 29, 2020, at 10:59 AM, Alfio Rizzo via Tech-talk <[email protected]> wrote:
I was wondering if the the correct way to get the PV aliased name is to look at the .NAME field of its alias.
If I do
Ø  pvget myalias.NAME
I should get the “real” PV name which the alias point to.
However this start to not be true if the length of the “real” PV name is > 39 chars ( <= 60 )
since the .NAME filed value is truncated to 39 chars (maybe  some limitation on DBR_STRING ?)
That is indeed the expected way to get the canonical name, and I can use caget's long string support to fetch names that are longer than 39 characters:
woz$ caget this-is-a-very-long-pvname-prefix:BaseVersion.NAME
this-is-a-very-long-pvname-prefix:BaseVersion.NAME this-is-a-very-long-pvname-prefix:BaseV
woz$ caget -S this-is-a-very-long-pvname-prefix:BaseVersion.NAME$
this-is-a-very-long-pvname-prefix:BaseVersion.NAME$ this-is-a-very-long-pvname-prefix:BaseVersion
Unfortunately pvget doesn’t provide any equivalent to the -S flag of caget, and I’m not aware of any functionality in QSRV that can handle long strings properly at the server end (which would be the right place to handle this):
woz$ pvget this-is-a-very-long-pvname-prefix:BaseVersion.NAME
this-is-a-very-long-pvname-prefix:BaseVersion.NAME 2020-10-29 11:11:09.355  this-is-a-very-long-pvname-prefix:BaseV
woz$ pvget this-is-a-very-long-pvname-prefix:BaseVersion.NAME$
this-is-a-very-long-pvname-prefix:BaseVersion.NAME$ 2020-10-29 11:11:09.355  [116,104,105,115,45,105,115,45,97,45,118,101,114,121,45,108,111,110,103,45,112,118,110,97,109,101,45,112,114,101,102,105,120,58,66,97,115,101,86,101,114,115,105,111,110,0]
There is an issue filed against QSRV for this, but nobody has proposed a good solution yet. Ideas and code contributions welcomed from any C++ developers out there!
- Andrew
Complexity comes for free, simplicity you have to work for.
get alias "real" name Alfio Rizzo via Tech-talk
Prev: get alias "real" name Alfio Rizzo via Tech-talk
Next: Re: Error in dbd/HPE3631Atest.dbd" line 12090 Johnson, Andrew N. via Tech-talk
Next: ArrayData read problem Jong Woo Kim via Tech-talk
