1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
From: Jeong Han Lee via Tech-talk <[email protected]>
To: "Shankar, Murali" <[email protected]>
Date: Fri, 30 Oct 2020 13:32:47 -0700
Hi Murali,
I have one naive question about the following situation.
After the archiver was started, in case that I have to change these variables.
* Should I restart the service after changing these variables?
* If so, is there any way to update them while the archiver is running?
Best,
Han
On Fri, Oct 30, 2020 at 7:55 AM Shankar, Murali via Tech-talk
<[email protected]> wrote:
> The archiver needs a proper EPICS setup for it to connect to the IOC's. The engine's arch.log should print out the actual CA configuration being used so you can look there to see if the EPICS setup was inherited correctly from your .profile.
> Regards,
> Murali
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
RE: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
Prev: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Next: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
