Hi Murali,
I have one naive question about the following situation.
After the archiver was started, in case that I have to change these variables.
* Should I restart the service after changing these variables?
* If so, is there any way to update them while the archiver is running?
Best,
Han
On Fri, Oct 30, 2020 at 7:55 AM Shankar, Murali via Tech-talk
[email protected]> wrote:
> The archiver needs a proper EPICS setup for it to connect to the IOC's. The engine's arch.log should print out the actual CA configuration being used so you can look there to see if the EPICS setup was inherited correctly from your .profile.
> Regards,
> Murali
