Subject: EPICS How-To , Installation on Windows
From: John Dobbins via Tech-talk <[email protected]>
Date: Mon, 2 Nov 2020 17:01:46 +0000
All,
I am attempting to install EPICS on Windows 10 per the EPICS "How-To"
I encounter the errors shown below.
Note that I am not wedded to this method of installation. (I have installed on Windows before but so infrequently that each time is a new adventure.)
Any advice appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
../osi/os/WIN32/epicsTempFile.cpp: In function ‘FILE* epicsTempFile()’:
../osi/os/WIN32/epicsTempFile.cpp:33:20: error: ‘_tempnam’ was not declared in this scope; did you mean ‘tempnam’?
   33 |     char * pName = _tempnam ( "c:\\tmp", "epics" );
      |                    tempnam
../osi/os/WIN32/epicsTempFile.cpp:49:26: error: ‘_O_CREAT’ was not declared in this scope; did you mean ‘O_CREAT’?
   49 |     const int openFlag = _O_CREAT | _O_EXCL | _O_RDWR |
      |                          O_CREAT
../osi/os/WIN32/epicsTempFile.cpp:49:37: error: ‘_O_EXCL’ was not declared in this scope; did you mean ‘O_EXCL’?
      |                                     O_EXCL
../osi/os/WIN32/epicsTempFile.cpp:49:47: error: ‘_O_RDWR’ was not declared in this scope; did you mean ‘O_RDWR’?
      |                                               O_RDWR
../osi/os/WIN32/epicsTempFile.cpp:50:9: error: ‘_O_SHORT_LIVED’ was not declared in this scope
   50 |         _O_SHORT_LIVED | _O_BINARY | _O_TEMPORARY;
../osi/os/WIN32/epicsTempFile.cpp:50:26: error: ‘_O_BINARY’ was not declared in this scope; did you mean ‘O_BINARY’?
      |                          O_BINARY
../osi/os/WIN32/epicsTempFile.cpp:50:38: error: ‘_O_TEMPORARY’ was not declared in this scope
../osi/os/WIN32/epicsTempFile.cpp:51:38: error: ‘_S_IWRITE’ was not declared in this scope; did you mean ‘S_IWRITE’?
   51 |     int fd = open ( pName, openFlag, _S_IWRITE );
      |                                      S_IWRITE
../osi/os/WIN32/epicsTempFile.cpp:54:20: error: ‘_fdopen’ was not declared in this scope; did you mean ‘fdopen’?
   54 |         pNewFile = _fdopen ( fd, "w+b" );
      |                    fdopen
../osi/os/WIN32/epicsTempFile.cpp:59:43: error: ‘errno’ was not declared in this scope
   59 |             "\"%s\"\n", pName, strerror ( errno ) );
../osi/os/WIN32/epicsTempFile.cpp:23:1: note: ‘errno’ is defined in header ‘<cerrno>’; did you forget to ‘#include <cerrno>’?
   22 | #include "epicsTempFile.h"
  +++ |+#include <cerrno>
   23 |
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'antelope.exe'.  Stop.
make[4]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules/libcom/src/O.windows-x64-mingw'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[3]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:84: src.install] Error 2
make[2]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:84: libcom.install] Error 2
make[1]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules'
make: *** [configure/RULES_DIRS:84: modules.install] Error 2
RE: EPICS How-To , Installation on Windows Mark Rivers via Tech-talk
Prev: Re: LabView-EPICS Integration using SoftIoc Mostafa, Jalal (IPE) via Tech-talk
Next: Re: Accessing info fields via CA/PVA Johnson, Andrew N. via Tech-talk
Prev: RE: LabView-EPICS Integration using SoftIoc Baily, Scott A via Tech-talk
Next: RE: EPICS How-To , Installation on Windows Mark Rivers via Tech-talk
