1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: GPIB remote control
To: 'Eric Norum' <[email protected]>
Date: Thu, 5 Nov 2020 20:47:26 +0000
Hi Eric,
Thanks for the reply.
Ø  I wrote the ASYN driver for the Prologix device you mentioned.  It seemed to work with the few devices I tried.
You mean the standard asyn VXI-11 driver, right?
Ø  For your Moxa issue, I’d suggest putting a serial line analyzer, or at least one of these pass-through things with LEDs to show the status of the assorted RS-232 lines, between the LAN/Serial and Serial/GPIB devices.
I’ll try that the next time I am at the lab.
Ø  Are you using the same serial line cable as before?
Yes.
Sent: Thursday, November 5, 2020 1:29 PM
Cc: [email protected]
Subject: Re: GPIB remote control
It’s been a while since I used one, though.
For your Moxa issue, I’d suggest putting a serial line analyzer, or at least one of these pass-through things with LEDs to show the status of the assorted RS-232 lines, between the LAN/Serial and Serial/GPIB devices.  Are you using the same serial line cable as before?
On Nov 5, 2020, at 11:11 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
An inexpensive alternative would be an Ethernet to GPIB controller, such as this one from Prologix for $180.
http://prologix.biz/gpib-ethernet-controller.html
Does anyone have experience with these.
I have experience with the Agilent LAN/GPIB gateway, but those are expensive and appear to no longer be available.
Re: GPIB remote control Eric Norum via Tech-talk
GPIB remote control Mark Rivers via Tech-talk
Prev: Re: GPIB remote control Michael Davidsaver via Tech-talk
Next: RE: GPIB remote control Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: GPIB remote control Eric Norum via Tech-talk
