Subject: Re: read RVB and VAL don't match when moving smarAct motors without encoders
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Reinhardt, Juliane" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 12 Nov 2020 00:05:52 +0000
Juliane,
How does the MCS controller respond to the GST, GA and GP commands for
an axis without an encoder?  It should be possible to send them using an
asyn record or a terminal in the vendor software.
The MCS driver assumes every axis will have a sensor and sets the motor
record's problem bit if the GST command returns an error.
Kevin
On 11/11/20 4:14 PM, Juliane Reinhardt via Tech-talk wrote:
> Dear EPICS team,
> I have recently been setting up smarAct MCS controllers for a couple of
> smarAct motors, some of them have encoders and some don't. The 2 motors
> that don't have encoders don't move although they are connected properly
> (I assume). When I do "caput motor.VAL 0.5" I get the feedback for old
> and new VAL and when I check with "caget motor.VAL" it matches. However,
> the actual "caget motor.RBV" does not change accordingly and the motor
> did not move.
> What is required to move motors without an encoder in this case?
> Thanks,
> Juliane
Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Prev: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Next: Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
