Subject: Re: asyn connetion to wti
To: Hawi Stecher <[email protected]>
Cc: Eric Norum via Tech-talk <[email protected]>
Date: Fri, 20 Nov 2020 16:14:25 -0800
If you’re attempting to use asynSetOption to set the serial line parameters (bits, parity, etc.) then you need to have a terminal server that accepts RFC2217 commands.  Can you configure your terminal server to do this?
On Nov 20, 2020, at 4:09 PM, Hawi Stecher via Tech-talk <[email protected]> wrote:
Setting is as follows:
drvAsynIPPortConfigure("LS325_IP", "10.1.2.60:2302")
Tried COM:
drvAsynIPPortConfigure("LS325_IP", "10.1.2.60:2302 COM")
INFO -- asynInterposeCOM options extending and perhaps overriding those of lower interface.
WARNING -- Can't set serial port parameters: Device says DON'T 0x2c.
asynSetOption("LS325_IP", 0, "bits", "7")
setOption failed 10.1.2.60:2302 COM timeout: Resource temporarily unavailable
asynSetOption("LS325_IP", 0, "parity", "odd")
Eric Norum
[email protected]
asyn connetion to wti Hawi Stecher via Tech-talk
Re: asyn connetion to wti Eric Norum via Tech-talk
Re: asyn connetion to wti Hawi Stecher via Tech-talk
Prev: Re: asyn connetion to wti Hawi Stecher via Tech-talk
Next: Re: asyn connetion to wti Hawi Stecher via Tech-talk
Next: RE: asyn connetion to wti Mark Rivers via Tech-talk
