Sounds like the terminal server requires an RFC 2217 connection? How did you configure the ASYN port? Did you specify the ‘COM’ option?
I am trying to connect a softIOC using asyn and StreamDevice to a wti console server, which has a serial connection to a LakeShore325.
I am able to telnet to the wti and communicate with the LakeShore. I am also able to connect the softIOC to other devices and send messages.
There seems to be some issue between asyn and the wti, which is serving a standard telnet connection.
- Re: asyn connetion to wti Hawi Stecher via Tech-talk
- asyn connetion to wti Hawi Stecher via Tech-talk
New releases of the measComp module Mark Rivers via Tech-talk
RE: asyn connetion to wti Mark Rivers via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
