1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: New releases of the measComp module
Date: Fri, 20 Nov 2020 23:41:27 +0000
Folks,
Releases 2-5 and 2-5-1 of the measComp module are now available.
This is from the R2-5-1 release notes:
-drvMultiFunction.cpp
    - Fixed bug in waveform digitizer mode, current channel was being calculated incorrrectly.
    - Improved poller to reduce the number of error messages when the device is not available.
- E-1608::AInScanStart_E1608 (Linux)
    - Added 5 retries to start waveform acquisition. It appears that sometimes the connect() has not actually completed before acquisition is started, and the device returns a "not ready" status.
    - Improved error messages when acquisition does not start correctly.
    - Bug fix for 1-byte message not being sent correctly.
- mcBoard_E-1608.cpp (Linux)
    - Bug fix where lock was not taken when it should be.
This is from the R2-5 release notes:
- Improvements to USB-CTR04/08 support
    - Added support for reading the 8 digital I/O bits in the MCS scan. This allows capturing the status of input and output bits during a scan. There are now 9 MCS spectra: 8 for the counters and 1 for the digital I/O.
   - Added ability to select counters to use in the MCS on an individual basis, rather than the first and last counter to use. This also applies to the digital I/O word.
    - Added an AbsTimeWF waveform record containing the absolute time of each point in waveform digitizer and MCS scans.
    - Added support for cbDaqInScan and cbDaqSetTrigger on Linux.
    - Added TrigMode record to control the trigger mode of DaqInScan.
    - Fixed bugs on Linux when the number of counters selected was not a power of 2. The data could be wrong and it would stop before the number of channels to collect was reached.
- Added support for E-DIO24 module on Linux and Windows .
- Added autoconverted OPI files for edm, caQtDM, CSS-Boy and CSS-Phoebus.
- Updated the version of the Measurement Computing Windows UL library from 6.51 to 6.72.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
The source repository is on Github:
https://github.com/epics-modules/measComp
Cheers,
Prev: asyn connetion to wti Hawi Stecher via Tech-talk
Next: Re: asyn connetion to wti Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: asyn connetion to wti Maren Purves via Tech-talk
Next: Clean up library upon ioc exit Laurenz Rettig via Tech-talk
