FYI: don't have to use a web interface, you can log into those things (at least if they are the same ones we use) and set the serial line parameters manually. And yes, some devices need raw mode.
Maren East Asian Observatory
What is the make and model of your terminal server?
You either need to set the baud and parity with a Web interface or put it in the RFC mode like Eric said and then you can use asynSetOption to set them.
Sent from my iPhone
On Nov 20, 2020, at 6:21 PM, Hawi Stecher <[email protected]> wrote:
Ah got it. Here's the output:
iocInit: Reached initHookAfterCallbackInit
iocInit: Reached initHookAfterCaLinkInit
iocInit: Reached initHookAfterInitDrvSup
iocInit: Reached initHookAfterInitRecSup
iocInit: Reached initHookAfterInitDevSup
2020/11/20 14:19:54.013 10.1.2.60:2302<http://10.1.2.60:2302> write 7
*IDN?\r\n
2020/11/20 14:19:54.186 10.1.2.60:2302<http://10.1.2.60:2302> read 12
\377\375\030\377\375 \377\375#\377\375\'
2020/11/20 14:19:54.286377 LS325_IP top:TC1:ID: Timeout after reading 12 bytes "<ff>?<18><ff>"
2020/11/20 14:19:54.286501 _main_ top:TC1:ID: @init handler failed
2020/11/20 14:19:54.286527 _main_ top:TC1:ID: Record initialization failed
iocInit: Reached initHookAfterInitDatabase
iocInit: Reached initHookAfterFinishDevSup
iocInit: Reached initHookAfterScanInit
iocInit: Reached initHookAfterInitialProcess
iocInit: Reached initHookAfterCaServerInit
iocInit: Reached initHookAfterIocBuilt
iocInit: Reached initHookAtIocRun
iocInit: Reached initHookAfterDatabaseRunning
iocInit: Reached initHookAfterInterruptAccept
iocInit: Reached initHookAfterCaServerRunning
iocInit: Reached initHookAtEnd
iocInit: Reached initHookAfterIocRunning
## Start any sequence programs
#seq sncExample, "user=hstecherHost"
epics>
On Fri, Nov 20, 2020 at 2:06 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Hawi,
Sorry, I was not being clear.
Please disable the StreamDevice debugging.
Please add the following lines to your startup script, right after the drvAsynIPPortConfigure line:
asynTraceTraceIOMask(PORT, 0, ESCAPE)
asynSetTraceMask(PORT, 0, ERROR|DRIVER)
where you replace PORT with the name of the asyn port you created. I think it might be LS325_IP.
Then restart the IOC and send all of the output.
From: Hawi Stecher <[email protected]<mailto:[email protected]>>
Sent: Friday, November 20, 2020 5:53 PM
To: Mark Rivers <[email protected]<mailto:[email protected]>>
Subject: Re: asyn connetion to wti
Hi Mark,
Thanks for your help. Below is the complete output:
2020/11/20 13:47:01.010735 _main_ StreamEpics.cc:426: streamInitRecord(top:TC1:ID): SEVR=3
2020/11/20 13:47:01.010771 _main_ StreamEpics.cc:431: streamInitRecord(top:TC1:ID): create new Stream object
2020/11/20 13:47:01.010844 _main_ StreamEpics.cc:442: streamInitRecord(top:TC1:ID): parse link "LakeShore336.proto getID(top:TC1) LS325_IP 0"
2020/11/20 13:47:01.010868 _main_ StreamEpics.cc:447: streamInitRecord(top:TC1:ID): calling initRecord
2020/11/20 13:47:01.010878 _main_ StreamEpics.cc:630: Stream::initRecord top:TC1:ID: attachBus(LS325_IP, 0, "")
2020/11/20 13:47:01.010888 _main_ StreamBusInterface.cc:62: StreamBusInterface::find(top:TC1:ID, LS325_IP, 0, "")
2020/11/20 13:47:01.010896 _main_ StreamBusInterface.cc:68: StreamBusInterface::find top:TC1:ID check DebugInterface
2020/11/20 13:47:01.010906 _main_ StreamBusInterface.cc:71: StreamBusInterface::find DebugInterface does not match
2020/11/20 13:47:01.010913 _main_ StreamBusInterface.cc:68: StreamBusInterface::find top:TC1:ID check DummyInterface
2020/11/20 13:47:01.010929 _main_ StreamBusInterface.cc:71: StreamBusInterface::find DummyInterface does not match
2020/11/20 13:47:01.010937 _main_ StreamBusInterface.cc:68: StreamBusInterface::find top:TC1:ID check AsynDriverInterface
2020/11/20 13:47:01.010960 _main_ AsynDriverInterface.cc:334: AsynDriverInterface::getBusInterface(top:TC1:ID, LS325_IP, 0)
2020/11/20 13:47:01.010984 _main_ AsynDriverInterface.cc:253: AsynDriverInterface(top:TC1:ID)
2020/11/20 13:47:01.010994 _main_ AsynDriverInterface.cc:265: AsynDriverInterface(top:TC1:ID) createAsynUser
2020/11/20 13:47:01.011002 _main_ AsynDriverInterface.cc:276: AsynDriverInterface(top:TC1:ID) epicsTimerQueueActive::allocate(true)
2020/11/20 13:47:01.011010 _main_ AsynDriverInterface.cc:279: AsynDriverInterface(top:TC1:ID) timerQueue->createTimer()
2020/11/20 13:47:01.011018 _main_ AsynDriverInterface.cc:283: AsynDriverInterface(top:TC1:ID) done
2020/11/20 13:47:01.011027 _main_ AsynDriverInterface.cc:443: top:TC1:ID: AsynDriverInterface::connectToBus(LS325_IP, 0): pasynManager->connectDevice(0x940c88, LS325_IP, 0) = asynSuccess
2020/11/20 13:47:01.011037 _main_ AsynDriverInterface.cc:339: AsynDriverInterface::getBusInterface(LS325_IP, 0): new interface allocated
2020/11/20 13:47:01.011062 _main_ StreamBusInterface.cc:71: StreamBusInterface::find AsynDriverInterface matches
2020/11/20 13:47:01.011071 _main_ StreamCore.cc:172: StreamCore::attachBus(busname="LS325_IP", addr=0, param="") businterface=0x950870
2020/11/20 13:47:01.011080 _main_ StreamEpics.cc:640: Stream::initRecord top:TC1:ID: parse(LakeShore336.proto, getID(top:TC1))
2020/11/20 13:47:01.011110 _main_ StreamProtocol.cc:185: StreamProtocolParser::readFile: try '/gem_sw/test/hstecher/myLakeShore/db/LakeShore336.proto'
2020/11/20 13:47:01.013242 _main_ StreamProtocol.cc:547: StreamProtocolParser::readToken: Special ' '
2020/11/20 13:47:01.013270 _main_ StreamProtocol.cc:263: StreamProtocolParser::parseProtocol: token=' '
2020/11/20 13:47:01.013280 _main_ StreamProtocol.cc:553: StreamProtocolParser::readToken: word
2020/11/20 13:47:01.013290 _main_ StreamProtocol.cc:564: StreamProtocolParser::readToken: word='extrainput' c=' '
2020/11/20 13:47:01.013301 _main_ StreamProtocol.cc:263: StreamProtocolParser::parseProtocol: token='extrainput<00>&<00><00><00>'
2020/11/20 13:47:01.013311 _main_ StreamProtocol.cc:553: StreamProtocolParser::readToken: word
2020/11/20 13:47:01.013319 _main_ StreamProtocol.cc:564: StreamProtocolParser::readToken: word='ignore' c=';'
2020/11/20 13:47:01.013327 _main_ StreamProtocol.cc:592: StreamProtocolParser::parseValue:38: ignore<00>&<00><00><00>
2020/11/20 13:47:01.013335 _main_ StreamProtocol.cc:547: StreamProtocolParser::readToken: Special ';'
2020/11/20 13:47:01.013342 _main_ StreamProtocol.cc:592: StreamProtocolParser::parseValue:38: ;
2020/11/20 13:47:01.013352 _main_ StreamProtocol.cc:547: StreamProtocolParser::readToken: Special ' '
2020/11/20 13:47:01.013359 _main_ StreamProtocol.cc:263: StreamProtocolParser::parseProtocol: token=' '
2020/11/20 13:47:01.013366 _main_ StreamProtocol.cc:553: StreamProtocolParser::readToken: word
2020/11/20 13:47:01.013374 _main_ StreamProtocol.cc:564: StreamProtocolParser::readToken: word='replytimeout' c=' '
2020/11/20 13:47:01.013382 _main_ StreamProtocol.cc:263: StreamProtocolParser::parseProtocol: token='replytimeout<00>'<00><00><00>'
2020/11/20 13:47:01.013390 _main_ StreamProtocol.cc:553: StreamProtocolParser::readToken: word
2020/11/20 13:47:01.013397 _main_ StreamProtocol.cc:564: StreamProtocolParser::readToken: word='2000' c=';'
2020/11/20 13:47:01.013405 _main_ StreamProtocol.cc:592: StreamProtocolParser::parseValue:39: 2000<00>'<00><00><00>
2020/11/20 13:47:01.013413 _main_ StreamProtocol.cc:547: StreamProtocolParser::readToken: Special ';'
2020/11/20 13:47:01.013420 _main_ StreamProtocol.cc:592: StreamProtocolParser::parseValue:39: ;
2020/11/20 13:47:01.013429 _main_ StreamProtocol.cc:547: StreamProtocolParser::readToken: Special ' '
2020/11/20 13:47:01.013437 _main_ StreamProtocol.cc:263: StreamProtocolParser::parseProtocol: token=' '
2020/11/20 13:47:01.013444 _main_ StreamProtocol.cc:553: StreamProtocolParser::readToken: word
2020/11/20 13:47:01.013452 _main_ StreamProtocol.cc:564: StreamProtocolParser::readToken: word='terminator' c=' '
2020/11/20 13:47:01.013460 _main_ StreamProtocol.cc:263: StreamProtocolParser::parseProtocol: token='terminator<00>(<00><00><00>'
2020/11/20 13:47:01.013467 _main_ StreamProtocol.cc:553: StreamProtocolParser::readToken: word
2020/11/20 13:47:01.013475 _main_ StreamProtocol.cc:564: StreamProtocolParser::readToken: word='cr' c=' '
2020/11/20 13:47:01.013483 _main_ StreamProtocol.cc:592: StreamProtocolParser::parseValue:40: cr<00>(<00><00><00>
2020/11/20 13:47:01.287488 _main_ top:TC1:ID: @init handler failed
2020/11/20 13:47:01.287499 _main_ top:TC1:ID: Record initialization failed
2020/11/20 13:47:01.287507 _main_ StreamEpics.cc:460: streamInitRecord(top:TC1:ID) done status=0xffffffffffffffff
On Fri, Nov 20, 2020 at 1:45 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Please send the complete output when using ASYN_TRACEIO_ESCAPE and ASYN_TRACEIO_DRIVER on the asyn port. I want to see the write commands and read commands with timestamps.
From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of Hawi Stecher via Tech-talk
Sent: Friday, November 20, 2020 5:33 PM
To: [email protected]<mailto:[email protected]>
Subject: asyn connetion to wti
Dear All,
I am trying to connect a softIOC using asyn and StreamDevice to a wti console server, which has a serial connection to a LakeShore325.
I am able to telnet to the wti and communicate with the LakeShore. I am also able to connect the softIOC to other devices and send messages.
There seems to be some issue between asyn and the wti, which is serving a standard telnet connection.
The protocol file is:
ExtraInput = Ignore;
ReplyTimeout = 2000;
Terminator = CR LF;
getID {
out "*IDN?";
in "%s";
@init {out "*IDN?"; in "%s";}
Below is a log snippet from asyn. It seems to read the following data then timeout:
<ff>?<18><ff>?
Any help would be greatly appreciated.
Thank you,
Hawi
asyn log:
2020/11/20 13:25:25.278974 LS325_IP AsynDriverInterface.cc:969: AsynDriverInterface::readHandler(top:TC1:ID): device is now connected
2020/11/20 13:25:25.278983 LS325_IP AsynDriverInterface.cc:1007: AsynDriverInterface::readHandler(top:TC1:ID): received 1 of 1 bytes "<ff>" eomReason=CNT
2020/11/20 13:25:25.278994 LS325_IP StreamCore.cc:953: StreamCore::readCallback(top:TC1:ID, status=StreamIoSuccess input="<ff>", size=1)
2020/11/20 13:25:25.279011 LS325_IP StreamCore.cc:1009: StreamCore::readCallback(top:TC1:ID) inputBuffer="<ff>", size 1
2020/11/20 13:25:25.279023 LS325_IP StreamCore.cc:1054: StreamCore::readCallback(top:TC1:ID) inTerminator <0d><0a> not found
2020/11/20 13:25:25.279031 LS325_IP StreamCore.cc:1090: StreamCore::readCallback(top:TC1:ID) wait for more input
2020/11/20 13:25:25.279062 LS325_IP AsynDriverInterface.cc:1133: AsynDriverInterface::readHandler(top:TC1:ID) readMore=-1 bytesToRead=63
2020/11/20 13:25:25.279072 LS325_IP AsynDriverInterface.cc:955: AsynDriverInterface::readHandler(top:TC1:ID): ioAction=Read read(..., bytesToRead=63, ...) [timeout=0.1 sec]
2020/11/20 13:25:25.379257 LS325_IP AsynDriverInterface.cc:962: AsynDriverInterface::readHandler(top:TC1:ID): read returned asynTimeout: ioAction=Read received=11, eomReason=NONE, buffer="?<18><ff>? <ff>?#<ff>?'"
2020/11/20 13:25:25.379297 LS325_IP AsynDriverInterface.cc:969: AsynDriverInterface::readHandler(top:TC1:ID): device is now connected
2020/11/20 13:25:25.379307 LS325_IP AsynDriverInterface.cc:1069: AsynDriverInterface::readHandler(top:TC1:ID): ioAction=Read, timeout [0.1 sec] after 11 of 63 bytes "?<18><ff>? <ff>?#<ff>?'"
2020/11/20 13:25:25.379322 LS325_IP StreamCore.cc:953: StreamCore::readCallback(top:TC1:ID, status=StreamIoTimeout input="?<18><ff>? <ff>?#<ff>?'", size=11)
2020/11/20 13:25:25.379332 LS325_IP StreamCore.cc:1009: StreamCore::readCallback(top:TC1:ID) inputBuffer="<ff>?<18><ff>? <ff>?#<ff>?'", size 12
2020/11/20 13:25:25.379342 LS325_IP StreamCore.cc:1054: StreamCore::readCallback(top:TC1:ID) inTerminator <0d><0a> not found
2020/11/20 13:25:25.379355 LS325_IP top:TC1:ID: Timeout after reading 12 bytes "<ff>?<18><ff>"
2020/11/20 13:25:25.379373 LS325_IP StreamCore.cc:1119: StreamCore::readCallback(top:TC1:ID) input line: "<ff>?<18><ff>? <ff>?#<ff>?'"
2020/11/20 13:25:25.379393 LS325_IP StreamCore.cc:1209: StreamCore::matchInput(top:TC1:ID): format = "%s"
2020/11/20 13:25:25.379408 LS325_IP StreamEpics.cc:522: streamScanfN(top:TC1:ID,format=%s,maxStringSize=40)
2020/11/20 13:25:25.379428 LS325_IP StreamCore.cc:1536: StreamCore::scanValue(top:TC1:ID, format=%s, char*, maxlen=40) input="<ff>?<18><ff>? <ff>?#<ff>?'"
2020/11/20 13:25:25.379447 LS325_IP StreamCore.cc:1550: StreamCore::scanValue(top:TC1:ID) scanned "<ff>?<18><ff>?<00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00>"
2020/11/20 13:25:25.379457 LS325_IP StreamEpics.cc:531: streamScanfN(top:TC1:ID) success, value="<ff>?<18><ff>?"
2020/11/20 13:25:25.379466 LS325_IP StreamCore.cc:513: starting exception handler
- asyn connetion to wti Hawi Stecher via Tech-talk
- RE: asyn connetion to wti Mark Rivers via Tech-talk
- Re: asyn connetion to wti Hawi Stecher via Tech-talk
- Re: asyn connetion to wti Mark Rivers via Tech-talk
Re: calcout record, CP link, Cached Puts Michael Davidsaver via Tech-talk
<2020>
2025
2026
New releases of the measComp module Mark Rivers via Tech-talk
<2020>
2025
2026
