Subject: Re: asyn connetion to wti
From: Hawi Stecher via Tech-talk <[email protected]>
To: Eric Norum <[email protected]>
Date: Fri, 20 Nov 2020 14:43:34 -1000
The model is WTI RSM8R8-1. I just set it to raw mode and that did it!!
Thank you all for your help. I have learned a lot and truly appreciate it.
Hawi
On Fri, Nov 20, 2020 at 2:37 PM Eric Norum <[email protected]> wrote:
That reply looks like a TELNET message.  The first two characters are ‘Interpret as command’ and ‘DO’, — but I’m not quite sure what it’s asking to ‘do’ — a quick glance at some RFCs doesn’t show what 030 (24) means.
Can you configure your terminal server to 2217 mode, or to ‘raw’ mode?  There’s no support in ASYN for a ’TELNET’ terminal server — one that wants to use TELNET commands but doesn’t support RFC 2217.
On Nov 20, 2020, at 4:27 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
What is the make and model of your terminal server?
You either need to set the baud and parity with a Web interface or put it in the RFC mode like Eric said and then you can use asynSetOption to set them.
Sent from my iPhone
On Nov 20, 2020, at 6:21 PM, Hawi Stecher <[email protected]> wrote:
Ah got it. Here's the output:
iocInit: Reached initHookAfterCallbackInit
iocInit: Reached initHookAfterCaLinkInit
iocInit: Reached initHookAfterInitDrvSup
iocInit: Reached initHookAfterInitRecSup
iocInit: Reached initHookAfterInitDevSup
2020/11/20 14:19:54.013 10.1.2.60:2302<http://10.1.2.60:2302> write 7
*IDN?\r\n
2020/11/20 14:19:54.186 10.1.2.60:2302<http://10.1.2.60:2302> read 12
\377\375\030\377\375 \377\375#\377\375\'
2020/11/20 14:19:54.286377 LS325_IP top:TC1:ID: Timeout after reading 12 bytes "<ff>?<18><ff>"
2020/11/20 14:19:54.286501 _main_ top:TC1:ID: @init handler failed
2020/11/20 14:19:54.286527 _main_ top:TC1:ID: Record initialization failed
iocInit: Reached initHookAfterInitDatabase
iocInit: Reached initHookAfterFinishDevSup
iocInit: Reached initHookAfterScanInit
iocInit: Reached initHookAfterInitialProcess
iocInit: Reached initHookAfterCaServerInit
iocInit: Reached initHookAfterIocBuilt
iocInit: Reached initHookAtIocRun
iocInit: Reached initHookAfterDatabaseRunning
iocInit: Reached initHookAfterInterruptAccept
iocInit: Reached initHookAfterCaServerRunning
iocInit: Reached initHookAtEnd
iocInit: Reached initHookAfterIocRunning
## Start any sequence programs
#seq sncExample, "user=hstecherHost"
epics>
asyn connetion to wti Hawi Stecher via Tech-talk
RE: asyn connetion to wti Mark Rivers via Tech-talk
Re: asyn connetion to wti Hawi Stecher via Tech-talk
Re: asyn connetion to wti Mark Rivers via Tech-talk
Re: asyn connetion to wti Eric Norum via Tech-talk
Prev: Re: asyn connetion to wti Eric Norum via Tech-talk
Next: Re: asyn connetion to wti Maren Purves via Tech-talk
