Subject: RE: New Focus Motor support
To: 'John Dobbins' <[email protected]>
Date: Mon, 23 Nov 2020 18:45:37 +0000
John,
My initial response was only half-right.  It is true that drvPMNC87xx.cc is a Model 1 driver and 874xMotorDriver.cpp is a Model 3 driver.
But more importantly:
874xMotorDriver.cpp is only for the 874x controllers, as seen in the file name and in this comment in the source files:
         “Motor driver support for the NewFocus 874x series of controllers”
drvPMNC87xx.cc is only for the 875x controllers as seen from these definitions in drvPMNCCom.h
/* Picomotor Network Controllers */
enum PMNC_model
  PMNC8750,
  PMNC8752
/* Picomotor Drivers - use DRT Command to determine */
enum PMD_model
  PMD8753=1,        // 3 channel open-loop
  PMD8751=2        // 1 channel closed-loop
So you must use drvPMNC87xx.cc for the 8753.
Sent: Monday, November 23, 2020 9:26 AM
Cc: [email protected]
Subject: Re: New Focus Motor support
Also, I learned that the 8743 and the 8753 have different command sets . I discovered this when I actually tried to move motors on the 8753.
The newfocus8742.asyn.st.cmd.linux-x86  did not work with 8753 (it was sending 8742 type commands) while the st.cmd does.
Am I overlooking something in configuration?  Can the Model 3 driver work with the 8753?
John
Sent: Saturday, November 21, 2020 6:05 PM
To: John Dobbins <
[email protected]>
Cc:
[email protected] <[email protected]>
Hi John,
/motor/modules/motorNewFocus/newFocusApp/src contains 2 drivers:
- An old Model 1 driver in these source code files:
    - devPMNC87xx.cc
    - drvPMNC87xx.cc.
    - drvPMNCCom.h
    - NewFocusRegister.cc
    -  NewFocusRegister.h
- A new Model 3 in these source code files:
    - 874xMotorDriver.cpp
    - 874xMotorDriver.h
newfocus8742.asyn.st.cmd.linux-x86 is for the new Model 3 driver.
st.cmd and PMNC87xx.cmd are for the old Model 1 driver.
[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Saturday, November 21, 2020 3:24 PM
To:
[email protected]
Subject: New Focus Motor support
All,
I am using a New Focus motor for the first time. I have an 8752 controller. looking in
motor-R7-1/modules/motorNewFocus/iocs/newFocusIOC/iocBoot/iocNewFocus
I see two IOC start scripts.
st.cmd which loads PMNC87xx.cmd
and
The later appears to work for my controller.  What is the other?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu<http://www.chess.cornell.edu>
New Focus Motor support John Dobbins via Tech-talk
Re: New Focus Motor support Mark Rivers via Tech-talk
Re: New Focus Motor support John Dobbins via Tech-talk
Prev: Re: New Focus Motor support John Dobbins via Tech-talk
Next: New releases of dac128V, ip330, ipUnidig, modbus, mca, and quadEM Mark Rivers via Tech-talk
