Hi all,
I had a question regarding best practices for building a helper support library for EPICS applications as a part of the EPICS build system.
At the moment I have the following (seemingly working) structure, omitting some boilerplate that doesn't affect this question:
A Top level makefile that lists directories and their dependencies:
DIRS := $(DIRS) configure
DIRS := $(DIRS) uvcSupport
DIRS := $(DIRS) uvcSupport/libuvc
DIRS := $(DIRS) uvcApp
uvcSupport_DEPEND_DIRS += uvcSupport/libuvc
uvcApp_DEPEND_DIRS += uvcSupport
A *Support directory who's Makefile installs the appropriate header files and libraries:
SRC_DIRS += ../libuvc
INC += libuvc/libuvc.h
INC += libuvc/libuvc_config.h
INC += libuvc/libuvc_internal.h
INC += utlist.h
ifeq (linux-x86_64, $(findstring linux-x86_64, $(T_A)))
LIB_INSTALLS_Linux += ../libuvc/O.$(EPICS_HOST_ARCH)/libuvc.a
LIB_INSTALLS_Linux += ../libuvc/O.$(EPICS_HOST_ARCH)/libuvc.so
endif
And a directory containing modified source and header files designed to build with EPICS
for the helper library along with a Makefile to build them, located in the *Support dir:
LIBRARY = uvc
uvc_SRCS += ctrl.c
uvc_SRCS += ctrl-gen.c
uvc_SRCS += device.c
uvc_SRCS += diag.c
uvc_SRCS += frame.c
uvc_SRCS += frame-mjpeg.c
uvc_SRCS += init.c
uvc_SRCS += misc.c
uvc_SRCS += stream.c
uvc_LIBS += jpeg
uvc_SYS_LIBS += usb-1.0
This seems to build everything correctly, at least from the top level, however, I noticed that if I only run `make` from the *Support directory I get an error.
Ideally I'd like to be able to `make` the Support directory independently so some helper non-IOC programs can be built without building the entire IOC lib and
executable.
How would I go about doing this, or is the current solution the recommended "best practice"?
I currently have this sitting on a development branch here:
https://github.com/areaDetector/ADUVC/tree/libuvc-epics-build
Jakub
- Re: Best practice for compiling helper support library via EPICS build system Mark Rivers via Tech-talk
New releases of dac128V, ip330, ipUnidig, modbus, mca, and quadEM Mark Rivers via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
