Subject: Re: procServ --logstamp argument
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 24 Nov 2020 19:18:00 +0100
Well,
The idea is the following:
The strftime() call is used when logging.
If the stampformat is configured (optional argument to --logstamp), it is used in the strftime() call.
If the stampformat is not configured, it is set to the timeformat (argument to --timefmt) with brackets around and followed by a space. The default for timeformat is "%c".
But I have to admit that all testing of procServ is manual and not complete.
In your case, the optional argument to "--logstamp" seems to have been misinterpreted as an argument to "--logport"? That's weird.
Cheers,
~Ralph
On Tue, 24 Nov 2020 at 17:25, Mark Rivers <[email protected]> wrote:
Hi Ralph,
I am trying to have procServ output a timestamp in a user-specified format, and I don’t understand the syntax of –logstamp.
I am running procServ v2.8.0
corvette:/usr/local/bin>procServ --version
procServ Process Server 2.8.0
This is the help on the –logstamp option
corvette:/usr/local/bin>procServ -h
    --logstamp [<str>]    prefix log lines with timestamp [strftime format]
The default time format used in procServ is “%c”.  I would like to use “%c “, so there a blank space between the timestamp and the rest of the line.
Do I interpret help output correctly that the [] brackets in the argument to –logstamp are meant to symbolize “optional”, and that they should not be present in the command?  And that the optional argument is a user-defined timestamp format?
Here is my attempt, and the resulting procServ error.
/usr/local/bin/procServ --logstamp "%c " -n "13E1608_1_IOC" -L /home/epics/logs/13E1608_1.log 20332 /home/epics/support/CARS/iocBoot/ioc13MeasCompE1608_1/start_epics
Invalid socket spec '%c '
However, when I use –timefmt to specify the timestamp format it works.
/usr/local/bin/procServ --logstamp --timefmt "%c " -n "13E1608_1_IOC" -L /home/epics/logs/13E1608_1.log 20332 /home/epics/support/CARS/iocBoot/ioc13MeasCompE1608_1/start_epics
/usr/local/bin/procServ: spawning daemon process: 32064
It turns out that I no longer actually need to change the format, because v2.8.0 which I just updated to automatically adds brackets and a space between the timestamp and the rest of the line.
But it seems like the optional argument to –logstamp is not working, or I just don’t understand it?
RE: procServ --logstamp argument Mark Rivers via Tech-talk
Prev: Re: ADEiger for EIGER2 Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Next: RE: procServ --logstamp argument Mark Rivers via Tech-talk
Prev: procServ --logstamp argument Mark Rivers via Tech-talk
