Subject: Re: ADEiger for EIGER2
From: John Dobbins via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "Perez Juarez, Emilio (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Wed, 25 Nov 2020 01:40:07 +0000
I am trying to build with shared libraries. As far as I can make out the problem is that I was trying to build with a shared library installed in a non-standard location.
I work on administered computers. When I asked for a zmq install it was installed in /nfs/opt which is not a standard location for a system library.
areaDetector/ADEiger/configure/CONFIG_SITE ends with
# If zeromq is not installed as a system library, set its path here
#ZMQ = /home/bmartins/workspace/zmq
#ZMQ=/nfs/opt/zmq.sl7
#ZMQ_LIB = $(ZMQ)/lib/static
#ZMQ_INCLUDE = $(ZMQ)/include
but if I try and use these to tell it where to find the ZMQ lib, the build  then wants to include zmq as a static library.
(admittedly it does say "if zeromq is not installed as a system library")
In the end I had to move the zmq libraries to a standard location /usr/lib64
I don't know if there is a more elegant solution. Thanks.
John
Sent: Tuesday, November 24, 2020 6:18 PM
To: John Dobbins <[email protected]>; Perez Juarez, Emilio (DLSLtd,RAL,LSCI) <[email protected]>
Cc: [email protected] <[email protected]>
Hi John,
It looks to me that the problem is that it is looking for a static version of libzmq, and there is only a dynamic version.
In the master branch these are the lines from that Makefile:
ifdef ZMQ_LIB
  zmq_DIR        += $(ZMQ_LIB)
  PROD_LIBS      += zmq
else
  PROD_SYS_LIBS  += zmq
endif
Did you define ZMQ_LIB?   If you don't then it will search for it as a PROD_SYS_LIB, which means it will be fine with only a dynamic library.  I suspect you defined ZMQ_LIB so it is looking for a static version, because you are building statically.
This is what I get when I link.  I am also building statically.  Note that -lzmq is after -Bdynamic, so it finds the shareable version.
/usr/bin/g++ -o eigerDetectorApp -Wl,-Bstatic -L/home/epics/devel/areaDetector-3-10/ADEiger/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-10/ADEiger/iocs/eigerIOC/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-10/ADSupport/lib/linux-x86_64 -L/home/epics/devel/asyn-4-41/lib/linux-x86_64 -L/home/epics/devel/autosave-5-10/lib/linux-x86_64 -L/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -L/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -L/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -L/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -L/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -L/usr/local/epics-devel/base-7.0.4/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADEiger/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADEiger/iocs/eigerIOC/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/asyn-4-41/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/autosave-5-10/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics-devel/base-7.0.4/lib/linux-x86_64           -rdynamic -m64          eigerDetectorApp_registerRecordDeviceDriver.o eigerDetectorAppMain.o   -leigerDetector -lfrozen -lhdf5_hl -lNDPlugin -lADBase -lqsrv -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lzmq -lboost_system -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
When I run ldd on the eigerDetectorApp executable this is where it is finding libzmq.so
corvette:eigerIOC/eigerApp/src>ldd ../../bin/linux-x86_64/eigerDetectorApp
        linux-vdso.so.1 =>  (0x00007ffe9a3d1000)
        libzmq.so.5 => /lib64/libzmq.so.5 (0x00007f05b31f2000)
What version of Linux are you using?  I am using Centos 7 and I just installed the zmq package.
Sent: Tuesday, November 24, 2020 4:48 PM
To: Mark Rivers; Perez Juarez, Emilio (DLSLtd,RAL,LSCI)
New problem:
/usr/bin/g++ -o eigerDetectorApp -Wl,-Bstatic -L/nfs/chess/epics/det/support/areaDetector/ADEiger/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADEiger/iocs/eigerIOC/lib/linux-x86_64 -L/nfs/chess/epics/det/base-7.0.3/lib/linux-x86_64 -L/nfs/chess/epics/det/support/alive-R1-1-1/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADCore/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADSupport/lib/linux-x86_64 -L/nfs/chess/epics/det/support/asyn-R4-40-1/lib/linux-x86_64 -L/nfs/chess/epics/det/support/autosave-R5-10/lib/linux-x86_64 -L/nfs/chess/epics/det/support/busy-R1-7-2/lib/linux-x86_64 -L/nfs/chess/epics/det/support/calc-R3-7-3/lib/linux-x86_64 -L/nfs/chess/epics/det/support/iocStats-3-1-16/lib/linux-x86_64 -L/nfs/chess/epics/det/support/seq-2-2-6/lib/linux-x86_64 -L/nfs/chess/epics/det/support/sscan-R2-11-3/lib/linux-x86_64 -L/nfs/opt/zmq-4.3.1-23.3.x86_64/lib            -rdynamic -m64          eigerDetectorApp_registerRecordDeviceDriver.o eigerDetectorAppMain.o   -leigerDetector -lfrozen -lhdf5_hl -lzmq -lNDPlugin -lADBase -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lalive -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lzmq
but note the flag
and
jad22@chess62 $ ls -l /nfs/opt/zmq-4.3.1-23.3.x86_64/lib
lrwxrwxrwx 1 root root     21 Feb  8  2019 libpgm-5.2.so.0 -> libpgm-5.2.so.0.0.122
-rwxr-xr-x 1 root root 303296 Jan 28  2019 libpgm-5.2.so.0.0.122
lrwxrwxrwx 1 root root     21 Feb  8  2019 libpgm.so -> libpgm-5.2.so.0.0.122
lrwxrwxrwx 1 root root     19 Feb  8  2019 libsodium.so -> libsodium.so.18.1.1
lrwxrwxrwx 1 root root     19 Feb  8  2019 libsodium.so.18 -> libsodium.so.18.1.1
-rw-r--r-- 1 root root 421512 Jan  4  2019 libsodium.so.18.1.1
lrwxrwxrwx 1 root root     15 Feb  8  2019 libzmq.so -> libzmq.so.5.2.1
lrwxrwxrwx 1 root root     15 Feb  8  2019 libzmq.so.5 -> libzmq.so.5.2.1
-rwxr-xr-x 1 root root 663568 Jan 28  2019 libzmq.so.5.2.1
drwxr-xr-x 2 root root     22 Apr 24  2019 static
Is it uphappy with the libzmq version?
Does libsodium have to be executable?
Apologies for my ignorance.
John
Sent: Tuesday, November 24, 2020 3:55 PM
Hi John,
lz4 and bitshuffle are both provided in ADSupport/supportApp/bitshuffleSrc.  I would strongly recommend using those, and not your system versions.
I don't know why that code for lz4 and bitshuffle was added to eigerApp/src/Makefile.  It should not be needed. I would try deleting it.
Sent: Tuesday, November 24, 2020 1:29 PM
To: Perez Juarez, Emilio (DLSLtd,RAL,LSCI); Mark Rivers
Sorry, that got sent prematurely.
Sent: Tuesday, November 24, 2020 2:27 PM
To: Perez Juarez, Emilio (DLSLtd,RAL,LSCI) <[email protected]>; Mark Rivers <[email protected]>
I get a build error related to the lz4 library (see below) I poked around and I am confused about where lz4 gets configured. I am using base-7.0.3 , areaDetector-master (is that a problem?)
On out SL7 systems
>locate lz4
/usr/lib/liblz4.so.1
/usr/lib/liblz4.so.1.7.5
/usr/lib64/liblz4.so.1
/usr/lib64/liblz4.so.1.7.5
but I also thought bitshhuffle from ADSupport provides LZ4.
Finally, I see that
areaDetector/ADEiger/eigerApp/src/Makefile contains a section
ifdef LZ4_LIB
  lz4_DIR  += $(LZ4_LIB)
  LIB_LIBS += lz4
  bitshuffle_DIR += $(LZ4_LIB)
  LIB_LIBS       += bitshuffle
else
  LIB_SYS_LIBS  += lz4
  LIB_SYS_LIBS  += bitshuffle
endif
not in other ADEiger installs I have.
John
/usr/bin/g++ -o libeigerDetector.so -shared -fPIC -Wl,-hlibeigerDetector.so -L/nfs/chess/epics/det/support/areaDetector/ADEiger/lib/linux-x86_64 -L/nfs/chess/epics/det/base-7.0.3/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADCore/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADSupport/lib/linux-x86_64 -L/nfs/chess/epics/det/support/asyn-R4-40-1/lib/linux-x86_64 -L/nfs/opt/zmq-4.3.1-23.3.x86_64/lib -Wl,-rpath,/nfs/chess/epics/det/support/areaDetector/ADEiger/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/base-7.0.3/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/support/areaDetector/ADSupport/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/support/asyn-R4-40-1/lib/linux-x86_64 -Wl,-rpath,/nfs/opt/zmq-4.3.1-23.3.x86_64/lib           -rdynamic -m64          eigerDetector.o restApi.o streamApi.o eigerParam.o   -lzmq -lADBase -lasyn -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom  -llz4 -lbitshuffle -lhdf5_hl -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -llz4
collect2: error: ld returned 1 exit status
From: Perez Juarez, Emilio (DLSLtd,RAL,LSCI) <[email protected]>
Sent: Tuesday, November 24, 2020 11:47 AM
To: John Dobbins <[email protected]>; Mark Rivers <[email protected]>
Hi, here's another approach:
$ git clone https://github.com/areaDetector/ADEiger
$ cd ADEiger/
$ git fetch origin pull/30/head:pr-branch
$ git checkout pr-branch
I think this way you get the result of merging to the target branch
Kind Regards,
Emilio
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 24 November 2020 16:33
Hi John,
You can clone the repository issuing that pull request and then checkout that branch:
git clone https://github.com/dls-controls/ADEiger/
cd ADEiger
git checkout 1.8
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Tuesday, November 24, 2020 10:16 AM
To: [email protected]
Subject: ADEiger for EIGER2
All,
I have a new EIGER 2 detector. I understand that this
https://github.com/areaDetector/ADEiger/pull/30
is the appropriate ADEiger for an EIGER 2.  True?
Can someone tell me how to clone this pull?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu>>>
Re: ADEiger for EIGER2 Mark Rivers via Tech-talk
ADEiger for EIGER2 John Dobbins via Tech-talk
Re: ADEiger for EIGER2 Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Re: ADEiger for EIGER2 John Dobbins via Tech-talk
Prev: Re: ADEiger for EIGER2 Mark Rivers via Tech-talk
Next: Re: ADEiger for EIGER2 Mark Rivers via Tech-talk
