1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: ADEiger for EIGER2
To: John Dobbins <[email protected]>, "Perez Juarez, Emilio (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Wed, 25 Nov 2020 02:37:32 +0000
> In the end I had to move the zmq libraries to a standard location /usr/lib64
> I don't know if there is a more elegant solution.
If you were able to do that, then I think the more elegant solution would be
sudo yum install zeromq-devel
Why would your administrators object to that?
Another solution would be to add something like this to your CONFIG_SITE:
USR_LDFLAGS += -L/opt/zmq.sl7/lib
Sent: Tuesday, November 24, 2020 7:40 PM
To: Mark Rivers; Perez Juarez, Emilio (DLSLtd,RAL,LSCI)
Cc: [email protected]
I am trying to build with shared libraries. As far as I can make out the problem is that I was trying to build with a shared library installed in a non-standard location.
I work on administered computers. When I asked for a zmq install it was installed in /nfs/opt which is not a standard location for a system library.
areaDetector/ADEiger/configure/CONFIG_SITE ends with
# If zeromq is not installed as a system library, set its path here
#ZMQ = /home/bmartins/workspace/zmq
#ZMQ=/nfs/opt/zmq.sl7
#ZMQ_LIB = $(ZMQ)/lib/static
#ZMQ_INCLUDE = $(ZMQ)/include
but if I try and use these to tell it where to find the ZMQ lib, the build  then wants to include zmq as a static library.
(admittedly it does say "if zeromq is not installed as a system library")
I don't know if there is a more elegant solution. Thanks.
John
Sent: Tuesday, November 24, 2020 6:18 PM
To: John Dobbins <[email protected]>; Perez Juarez, Emilio (DLSLtd,RAL,LSCI) <[email protected]>
Cc: [email protected] <[email protected]>
Hi John,
It looks to me that the problem is that it is looking for a static version of libzmq, and there is only a dynamic version.
In the master branch these are the lines from that Makefile:
ifdef ZMQ_LIB
  zmq_DIR        += $(ZMQ_LIB)
  PROD_LIBS      += zmq
else
  PROD_SYS_LIBS  += zmq
endif
Did you define ZMQ_LIB?   If you don't then it will search for it as a PROD_SYS_LIB, which means it will be fine with only a dynamic library.  I suspect you defined ZMQ_LIB so it is looking for a static version, because you are building statically.
This is what I get when I link.  I am also building statically.  Note that -lzmq is after -Bdynamic, so it finds the shareable version.
/usr/bin/g++ -o eigerDetectorApp -Wl,-Bstatic -L/home/epics/devel/areaDetector-3-10/ADEiger/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-10/ADEiger/iocs/eigerIOC/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64 -L/home/epics/devel/areaDetector-3-10/ADSupport/lib/linux-x86_64 -L/home/epics/devel/asyn-4-41/lib/linux-x86_64 -L/home/epics/devel/autosave-5-10/lib/linux-x86_64 -L/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -L/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -L/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -L/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -L/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -L/usr/local/epics-devel/base-7.0.4/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADEiger/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADEiger/iocs/eigerIOC/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/areaDetector-3-10/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/asyn-4-41/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/autosave-5-10/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/busy-1-7-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/calc-3-7-3/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/devIocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/seq-2-2-5/lib/linux-x86_64 -Wl,-rpath,/home/epics/devel/sscan-2-11-3/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics-devel/base-7.0.4/lib/linux-x86_64           -rdynamic -m64          eigerDetectorApp_registerRecordDeviceDriver.o eigerDetectorAppMain.o   -leigerDetector -lfrozen -lhdf5_hl -lNDPlugin -lADBase -lqsrv -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lzmq -lboost_system -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
When I run ldd on the eigerDetectorApp executable this is where it is finding libzmq.so
corvette:eigerIOC/eigerApp/src>ldd ../../bin/linux-x86_64/eigerDetectorApp
        linux-vdso.so.1 =>  (0x00007ffe9a3d1000)
        libzmq.so.5 => /lib64/libzmq.so.5 (0x00007f05b31f2000)
What version of Linux are you using?  I am using Centos 7 and I just installed the zmq package.
Sent: Tuesday, November 24, 2020 4:48 PM
New problem:
/usr/bin/g++ -o eigerDetectorApp -Wl,-Bstatic -L/nfs/chess/epics/det/support/areaDetector/ADEiger/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADEiger/iocs/eigerIOC/lib/linux-x86_64 -L/nfs/chess/epics/det/base-7.0.3/lib/linux-x86_64 -L/nfs/chess/epics/det/support/alive-R1-1-1/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADCore/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADSupport/lib/linux-x86_64 -L/nfs/chess/epics/det/support/asyn-R4-40-1/lib/linux-x86_64 -L/nfs/chess/epics/det/support/autosave-R5-10/lib/linux-x86_64 -L/nfs/chess/epics/det/support/busy-R1-7-2/lib/linux-x86_64 -L/nfs/chess/epics/det/support/calc-R3-7-3/lib/linux-x86_64 -L/nfs/chess/epics/det/support/iocStats-3-1-16/lib/linux-x86_64 -L/nfs/chess/epics/det/support/seq-2-2-6/lib/linux-x86_64 -L/nfs/chess/epics/det/support/sscan-R2-11-3/lib/linux-x86_64 -L/nfs/opt/zmq-4.3.1-23.3.x86_64/lib            -rdynamic -m64          eigerDetectorApp_registerRecordDeviceDriver.o eigerDetectorAppMain.o   -leigerDetector -lfrozen -lhdf5_hl -lzmq -lNDPlugin -lADBase -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lalive -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lzmq
but note the flag
and
jad22@chess62 $ ls -l /nfs/opt/zmq-4.3.1-23.3.x86_64/lib
lrwxrwxrwx 1 root root     21 Feb  8  2019 libpgm-5.2.so.0 -> libpgm-5.2.so.0.0.122
-rwxr-xr-x 1 root root 303296 Jan 28  2019 libpgm-5.2.so.0.0.122
lrwxrwxrwx 1 root root     21 Feb  8  2019 libpgm.so -> libpgm-5.2.so.0.0.122
lrwxrwxrwx 1 root root     19 Feb  8  2019 libsodium.so -> libsodium.so.18.1.1
lrwxrwxrwx 1 root root     19 Feb  8  2019 libsodium.so.18 -> libsodium.so.18.1.1
-rw-r--r-- 1 root root 421512 Jan  4  2019 libsodium.so.18.1.1
lrwxrwxrwx 1 root root     15 Feb  8  2019 libzmq.so -> libzmq.so.5.2.1
lrwxrwxrwx 1 root root     15 Feb  8  2019 libzmq.so.5 -> libzmq.so.5.2.1
-rwxr-xr-x 1 root root 663568 Jan 28  2019 libzmq.so.5.2.1
drwxr-xr-x 2 root root     22 Apr 24  2019 static
Is it uphappy with the libzmq version?
Does libsodium have to be executable?
Apologies for my ignorance.
John
Sent: Tuesday, November 24, 2020 3:55 PM
Hi John,
lz4 and bitshuffle are both provided in ADSupport/supportApp/bitshuffleSrc.  I would strongly recommend using those, and not your system versions.
I don't know why that code for lz4 and bitshuffle was added to eigerApp/src/Makefile.  It should not be needed. I would try deleting it.
Sent: Tuesday, November 24, 2020 1:29 PM
To: Perez Juarez, Emilio (DLSLtd,RAL,LSCI); Mark Rivers
Sorry, that got sent prematurely.
Sent: Tuesday, November 24, 2020 2:27 PM
To: Perez Juarez, Emilio (DLSLtd,RAL,LSCI) <[email protected]>; Mark Rivers <[email protected]>
I get a build error related to the lz4 library (see below) I poked around and I am confused about where lz4 gets configured. I am using base-7.0.3 , areaDetector-master (is that a problem?)
On out SL7 systems
>locate lz4
/usr/lib/liblz4.so.1
/usr/lib/liblz4.so.1.7.5
/usr/lib64/liblz4.so.1
/usr/lib64/liblz4.so.1.7.5
but I also thought bitshhuffle from ADSupport provides LZ4.
Finally, I see that
areaDetector/ADEiger/eigerApp/src/Makefile contains a section
ifdef LZ4_LIB
  lz4_DIR  += $(LZ4_LIB)
  LIB_LIBS += lz4
  bitshuffle_DIR += $(LZ4_LIB)
  LIB_LIBS       += bitshuffle
else
  LIB_SYS_LIBS  += lz4
  LIB_SYS_LIBS  += bitshuffle
endif
not in other ADEiger installs I have.
John
/usr/bin/g++ -o libeigerDetector.so -shared -fPIC -Wl,-hlibeigerDetector.so -L/nfs/chess/epics/det/support/areaDetector/ADEiger/lib/linux-x86_64 -L/nfs/chess/epics/det/base-7.0.3/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADCore/lib/linux-x86_64 -L/nfs/chess/epics/det/support/areaDetector/ADSupport/lib/linux-x86_64 -L/nfs/chess/epics/det/support/asyn-R4-40-1/lib/linux-x86_64 -L/nfs/opt/zmq-4.3.1-23.3.x86_64/lib -Wl,-rpath,/nfs/chess/epics/det/support/areaDetector/ADEiger/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/base-7.0.3/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/support/areaDetector/ADCore/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/support/areaDetector/ADSupport/lib/linux-x86_64 -Wl,-rpath,/nfs/chess/epics/det/support/asyn-R4-40-1/lib/linux-x86_64 -Wl,-rpath,/nfs/opt/zmq-4.3.1-23.3.x86_64/lib           -rdynamic -m64          eigerDetector.o restApi.o streamApi.o eigerParam.o   -lzmq -lADBase -lasyn -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom  -llz4 -lbitshuffle -lhdf5_hl -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -llz4
collect2: error: ld returned 1 exit status
From: Perez Juarez, Emilio (DLSLtd,RAL,LSCI) <[email protected]>
Sent: Tuesday, November 24, 2020 11:47 AM
To: John Dobbins <[email protected]>; Mark Rivers <[email protected]>
Hi, here's another approach:
$ git clone https://github.com/areaDetector/ADEiger
$ cd ADEiger/
$ git fetch origin pull/30/head:pr-branch
$ git checkout pr-branch
I think this way you get the result of merging to the target branch
Kind Regards,
Emilio
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 24 November 2020 16:33
Hi John,
You can clone the repository issuing that pull request and then checkout that branch:
git clone https://github.com/dls-controls/ADEiger/
cd ADEiger
git checkout 1.8
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Tuesday, November 24, 2020 10:16 AM
To: [email protected]
Subject: ADEiger for EIGER2
All,
I have a new EIGER 2 detector. I understand that this
https://github.com/areaDetector/ADEiger/pull/30
is the appropriate ADEiger for an EIGER 2.  True?
Can someone tell me how to clone this pull?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu>>>>
ADEiger for EIGER2 John Dobbins via Tech-talk
Re: ADEiger for EIGER2 Mark Rivers via Tech-talk
Re: ADEiger for EIGER2 Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Re: ADEiger for EIGER2 John Dobbins via Tech-talk
Prev: Re: ADEiger for EIGER2 John Dobbins via Tech-talk
Next: Re: device support for Keithley 2450 Brown, Garth via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: procServ --logstamp argument Mark Rivers via Tech-talk
