Probably a bit too late on this response, but if it helps, I've been working on the automation of a Lecroy Wavepro 404HD, which should be compatible with the 245HD as well.
The code is in this repository (still not documented at all):
https://gitlab.esss.lu.se/beam-diagnostics/bde/modules/wavepro
Cheers,
Henrique Silva
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Sent: 20 October 2020 22:55:11
To: EPICS tech-talk
Subject: Supported 'Scopes?
I’ve been given a list of possible ’scopes to select for an APS Upgrade application, does anyone have experience using any of these with EPICS and can provide device support for one (hopefully as a StreamDevice protocol file and database):
Keysight DSO204A
Keysight DSOS054A
Teledyne/LeCroy Wavepro 245HD
Thanks in advance,
- Andrew
Complexity comes for free, simplicity you have to work for.
- Re: Supported 'Scopes? Hu, Yong via Tech-talk
- Supported 'Scopes? Johnson, Andrew N. via Tech-talk
Alarm indicator in CSS Donny Domagoj Cosic via Tech-talk
RE:Alarm indicator in CSS GAGET Alexis via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
