1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Looking for help on PMD101 EPICS driver
To: tech-talk <[email protected]>
Date: Tue, 1 Dec 2020 09:22:50 +0800
Hello everyone,
      I have a problem when using a EPICS program for pmd101 controller.
      The pmd101 EPICS software is downloaded on the website" https://github.com/search?q=piezoMotor+epics", which is not attatched because it is too big.
      I change the communication type from TCP/IP to RS232, and use only one pmd101 controller other than three controllers in the downloaded file. Which means I change the configuration in st.cmd file, and in motor.sub, as well as the paths in  configure/RELEASE.
     The st.cmd file is also attatched and the motor.sub looks like this
      you can delete the '.txt' in the attatched 'st.cmd.txt' and get the st.cmd file.
     When I run the <top>/op/opi,  set the macros "Sys=XF:03IDC-ES, Dev={ZpTpa-Ax:Y}, P=XF:03IDC-ES{ZpTpa-Ax:Y}, M=Mtr " The result is like this:
     It shows PVs write with stream devices runs correctly. But the PV about the motor driver failed.
     Has anybody used the pmd101 controller?  Or do you have any advice on the program? Why the left part of the opi can't run correctly?
    Looking forward to your help.
    Thank you very much for any of your advice.
Best wishes.
Chunxia Yin
Attachment: st.cmd.txt
Description: Binary data
Re: Looking for help on PMD101 EPICS driver Mark Rivers via Tech-talk
Prev: Re: device support for Keithley 2450 Brown, Garth via Tech-talk
Next: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: aSub debug output Daykin, Evan via Tech-talk
Next: Re: Looking for help on PMD101 EPICS driver Mark Rivers via Tech-talk
