Subject: RE: Epics Archiver not pushing to STS?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 1 Dec 2020 21:23:00 +0000
I assume the VAL field is a default archived field even though its not listed here?  I did also notice that the details shows the events counter lost incrementing shown below at 689.  I must not have a setting correctly in the record for it to not archive.
caLab:dmm AI record
Archive Fields	HIHI,HIGH,LOW,LOLO,LOPR,HOPR
How many events lost because the timestamp is in the far future or past so far?	689
Timestamp of last event from the IOC - correct or not.	Dec/01/2020 15:27:22 -08:00
How many events lost because the sample buffer is full so far?	0
How many events lost because the DBR_Type of the PV has changed from what it used to be?	0
How many events lost totally so far?	689
I looked at another PV that I have running locally that is being archived correctly and stored but this is an AO record
Calc:a
Archive Fields	DRVH,HIHI,HIGH,DRVL,LOW,LOLO,LOPR,HOPR
-----Original Message-----
Sent: Monday, November 30, 2020 7:05 PM
To: Manoussakis, Adamandios <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Subject: Re: Epics Archiver not pushing to STS?
On 11/30/20 5:38 PM, Manoussakis, Adamandios via Tech-talk wrote:
> Hello All,
> I have been successful in getting the epics archiver appliance to archive PVs that are running in soft IOCs locally on the same machine as the archiver.  But now I tried to archive an IOC that is running on a subnet 192.168.40.x and it is says its connected/archiving but it never pushes to STS. It does show the details from the record for caLab:dmm shown below, which seems like its able to read from it. Settings for archiver appliance.xml below and also the archappl.conf environment variables set for the subnet to be seen.  I am able to also use caget through cmdline to get values from caLab:dmm and CSStudio is able to monitor them but the archiver doesn't seem to be actually saving the data.
The info you paste below seems contradictory.  The summary table shows "caLab:dmm" as connected, but the details table shows a disconnected PV.
You mention caget.  Does camonitor work?  eg.
> $ camonitor caLab:dmm caLab:dmm.HIHI
Note the extra "Archive Fields" listed in the details table (eg. HIHI) also need to exist.
> <appliances>
>    <appliance>
>      <identity>appliance0</identity>
>      <cluster_inetport>localhost:16670</cluster_inetport>
>      <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url
> <http://localhost:17665/mgmt/bpl%3c/mgmt_url>>
>      <engine_url>http://localhost:17666/engine/bpl</engine_url
> <http://localhost:17666/engine/bpl%3c/engine_url>>
>      <etl_url>http://localhost:17667/etl/bpl</etl_url
> <http://localhost:17667/etl/bpl%3c/etl_url>>
> <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url
> <http://localhost:17668/retrieval/bpl%3c/retrieval_url>>
> <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_u
> rl <http://localhost:17668/retrieval%3c/data_retrieval_url>>
>    </appliance>
> </appliances>
> JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
> JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
> CATALINA_HOME="/usr/share/tomcat9"
> CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
> ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
> ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
> ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
> ARCHAPPL_MYIDENTITY="appliance0"
> ARCHAPPL_STORAGE_TOP="/arch"
> ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
> ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
> ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
> EPICS_CA_ADDR_LIST=192.168.40.200
> EPICS_CA_AUTO_ADDR_LIST=YES
> *caLab:dmm PV details section showing Never for STS push*
Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Re: Epics Archiver not pushing to STS? Michael Davidsaver via Tech-talk
Prev: RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Next: RE: Epics Archiver not pushing to STS? Manoussakis, Adamandios via Tech-talk
Prev: Re: Epics Archiver not pushing to STS? Michael Davidsaver via Tech-talk
Next: Re: Epics Archiver not pushing to STS? Jeong Han Lee via Tech-talk
